my graph for you to see
Old Apr 12, 2008 | 07:24 PM
lankypicker's Avatar
lankypicker
Default my graph for you to see
from todays rr day
well chuffed!!
mods are:-
air to air, gt28, pd manifold & miltek exhaust
Old Apr 12, 2008 | 07:28 PM
Mark Shead's Avatar
Mark Shead
So your chuffed with boarderling AFR after 6k,
Dont tell me it has a bluefin at this level it will be detting above 5.5k, I have seen many of these like this.
Mark
Old Apr 12, 2008 | 07:33 PM
lankypicker
no wonder no-one posts in here
Old Apr 12, 2008 | 07:37 PM
Mark Shead's Avatar
Mark Shead
So you dont want any comments stating TOTD said AFR borderline and you should be carefulas I guess they told you this also.
Markl
Old Apr 12, 2008 | 08:15 PM
pani_k's Avatar
pani_k
PassionFORD Member
i just read this and i dont know what afr is
educated guess: air fuel ratio?
what does the afr borderline mean?
Old Apr 12, 2008 | 08:20 PM
Mark Shead's Avatar
Mark Shead
Yes correct,
Post up afr graph.
Mark
Old Apr 13, 2008 | 08:54 AM
pani k,
You need to maintain a certain AFR, richness around max power, otherwise things get a bit hot and start melting.
MS is just saying it is getting a little on the lean side of rich enough, as though fuel is lacking a bit.
Old Apr 13, 2008 | 10:36 AM
pani_k's Avatar
pani_k
PassionFORD Member
ahh right ok i seem to understand now. so when you are reaching your limits, things start to get a bit dangerous and you risk component failure because of an inadequate healthy afr ratio as I understand.
Old Apr 13, 2008 | 06:32 PM
Yes basically they use rich mixtures as a form of cooling and det resistance.
whilst brits favour rich our cousins over the pond have a saying LEAN IS MEAN!!
Old Apr 17, 2008 | 10:55 AM
gingeRS's Avatar
gingeRS
Originally Posted by Mark Shead
Yes correct,
Post up afr graph.
Mark
What AFR's should we be seeing at 6000rpm?
i have my AFR graph at home from the same RR day and chris todd suggested it maybr running too rich at the top end and killing the power
car has a bluefin and decat
Old Apr 17, 2008 | 03:54 PM
pani_k's Avatar
pani_k
PassionFORD Member
rather rich than lean. at least you know its safe at the top end
Old Apr 19, 2008 | 05:13 PM
lankypicker
afr graph
Old Apr 19, 2008 | 11:40 PM
pani_k's Avatar
pani_k
PassionFORD Member
havent got a clue what that graph means lol!
Old Apr 19, 2008 | 11:46 PM
Kverna's Avatar
Kverna
Virgin-popper
AFR is the dotted line. You can see it just starts to lean out when the operator aborts around 6400
Old Apr 21, 2008 | 08:42 PM
simon170's Avatar
simon170
28RS or 28R?
Lankpicker: take advantage of Marks and Chris's skill, if they its not right, then its not right needs looking at. Cheaper than the alternative...
Chas
Sep 21, 2015 08:57 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
Christian and Beccy
34
Feb 6, 2006 01:31 PM
Billabong
69
Oct 2, 2005 04:35 PM
