CPS current
Old Apr 11, 2008 | 08:36 PM
Gregor's Avatar
Gregor
Default CPS current
Can someone tell me how high the current should be that comes off the crankshaft position sensor.
thanks
Old Apr 12, 2008 | 01:42 PM
Rick's Avatar
Rick
It isn't a current, it's an AC voltage. It increases with amplitude and frequency with engine speed. At cranking speeds, you should have around 3V minimum, it will rise to 100+ with speed. With engine stopped, it will be zero.
Old Apr 12, 2008 | 08:44 PM
Gregor's Avatar
Gregor
Yea sorry my bad.
It's no current... was thinking voltage...( i'm not Englisch )
But anyway, so at cranking i should see 3v if i messure it at the sensor when its not connected to the ecu...
Will see what i get tomorrow..
Thanks
Old Apr 13, 2008 | 11:58 AM
DazC's Avatar
DazC
From memory, I usually see 2.5v at cranking across the 2 terminals (ECU disconnected).
Old Apr 13, 2008 | 01:34 PM
Gregor's Avatar
Gregor
Thanks mate, i'll have a look at it
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
