coz cams, good or bad? and reusable head gaskets
Old Oct 22, 2004 | 07:44 PM
the strut brace's Avatar
the strut brace
Default coz cams, good or bad? and reusable head gaskets
going to go greys/t34 etc and if i buy a 1.44mm thick cometic wrc head gasket i'll be low comp, and was thinkin about changin my cams or just the inlet, is this a good idea ?
what would the right cam be for my engine, some say the bd14 some say leave the standard cams in, i'm confused as fuk as to what to put in, also if the 14 one is the one to go for , is the best thing to do send them to someone like amber for an exchange pair or is there someone else on here who does them?
Old Oct 22, 2004 | 07:47 PM
big_wig_074's Avatar
big_wig_074
get someone to check the spec of your motor like MSD(from your sig) and tell you which is best cos tbh at that level its not really a off the shelf game anymore.
Old Oct 22, 2004 | 08:38 PM
leesrs240's Avatar
leesrs240
Fen i thinks shes gona blow ,,,,o sorry it allready has
Old Oct 22, 2004 | 08:41 PM
the strut brace
shouldnt you be mason
Old Oct 22, 2004 | 08:42 PM
TIFF's Avatar
TIFF
Chasing Radders
I went through this with Karl and he can use his own NMS cams to unleash a few more ponys
Old Oct 22, 2004 | 08:46 PM
the strut brace
how much are those tif?
Old Oct 22, 2004 | 08:48 PM
TIFF's Avatar
TIFF
Chasing Radders
Not too sure mate, better off having a word with Karlos
Old Oct 22, 2004 | 08:49 PM
leesrs240's Avatar
leesrs240
Fen you could put a couple of broom shnks in there and get more power than you have now
Old Oct 22, 2004 | 09:14 PM
Moose 130's Avatar
Moose 130
To maintain decent torque, keep a std exhaust cam though.
Old Oct 22, 2004 | 10:24 PM
Stu @ M Developments's Avatar
PassionFords Creator
Need more info on your individual requirements to ascertain the correct cams to use Karl. Also dont forget that most of the popular cams require piston modifications and some require stronger valve springs and platform mods... Feel free to call me if you need to.
Old Oct 22, 2004 | 11:00 PM
the strut brace
cheers stu, you would be doin it anyways, i've asked about the 1.42 cometic gaskets which claim to lower comp, you got any opinions on these???
Old Oct 22, 2004 | 11:12 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
cometic are SHYYYYYYYYYTE with head gaskets,
1st blow out i put down to bad head, 2nd one fooked block and differnt head.
2nd time was the above mentioned gasket
might be a bad batch( ? ) but i certainly wouldnt use another one again as it cost me a LOT of money and even more in time, especially to prep the heads....... as you know i was really really gutted.
stick with gpA, for the money it costs/power output theres no point buying a reuseable gasket (Mountune ONLY! ) unless head is off a lot of reliability is a major factor and cost isnt.
Have a think about your motor, try not to listen to all the things everyone says as advice as it oftern makes things dificult to choose.
Try to have phone conversations with reputable tuners and tell them your requirements, they will give best advice possible and 99% of the time its free!!!!
Everyone knows how to get big horsepower cossie motors nowdays, but not everyone knows how to build GOOD cossie motors with reliability!
Head gaskets are a major factor in a cossie motor, dont believe everything you hear about most expensive bits being the best.... its all dependant on the application
Sean.
Old Oct 22, 2004 | 11:26 PM
the strut brace
sean, sometimes you sound like ya know what your talkin aboot
Old Oct 22, 2004 | 11:31 PM
Cossie Sean
i know, unfortunatley sometimes i do cos of my own experiances! Mainly bad ones
Old Oct 23, 2004 | 08:33 AM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
shaun NO headgasket IS REUSABLE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! cowboy
Old Oct 23, 2004 | 09:01 AM
the strut brace
gus, they are advertised as reuseable by pj etc so what do they mean by it if its not reusable???thats the impression i get, that you can use em more than once
Old Oct 23, 2004 | 09:02 AM
Rs Gus's Avatar
Rs Gus
no SO NOT EVER REUSE A HEADGASKET!!!!!!!!!!!
Old Oct 23, 2004 | 11:19 AM
the strut brace
so general opinion is dont use cometic! and theres no such thing as a reusable h.gasket
Old Oct 23, 2004 | 01:35 PM
leesrs240's Avatar
leesrs240
GRP A ALL THE WAY
markk
Dec 2, 2021 06:59 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
Mark RS
14
Aug 11, 2015 11:45 AM
mattman1234
24
Aug 1, 2015 11:46 AM
