Temp. Problem
Old Apr 9, 2008 | 09:20 PM
Dave_RS's Avatar
Dave_RS
Angry Temp. Problem
I will try to explain my problem the best i can, remember, i´m from Spain and my English isn´t good at all!
The problem is simple, the temperature goes up extremely fast (about 1 or 2 minutes from the mid of the gauge to really near of the red zone) when i stop for example in front of my garage, it keeps normal when i stop in a red light or a stop signal just cause it dosn´t have enough time for get hot.
Cause isn´t expensive, and it´s a simple piece of DIY i´ve changed today the antifreeze, the thermostat and i´ve cleaned the best i can all the coolant circuit and nothing changed, when i´m runing it keeps on the normal temperature but when i stay stopped about 2 minutes, it goes up near to the red zone.
Water pump totally ok, no leaks in any hoses, temp. gauge Ok, real temperature checked with a laboratory termometer (89ºC in the midle of the gauge, and 94/95ºC when it´s really near to the red zone) and anything extrange except:
The radiator fan starts ok nearly to 91ºC, but it doesn´t get the temperature down when it´s runing. No blades of it are broken, and it seems to run at the same speed of always... and that´s the extrange thing... why it will doesn´t getting it cold if it runs normally?
Thanks & CheeRS!
Old Apr 9, 2008 | 09:36 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
is it boiling over?
Old Apr 9, 2008 | 10:08 PM
Dave_RS's Avatar
Dave_RS
Originally Posted by jonnyrsturbo
is it boiling over?
No, at last not boiling in the expansion tank. But if i stop the engine when it´s hot, and i open the cap slowly getting the preassure out of the circuit, after a little moment i can hear some bubbles... so, can it be only some air on the cooling system? In that case, how can i purge the circuit totally?
Old Apr 10, 2008 | 04:19 AM
ymalool's Avatar
ymalool
Try to sense the heat of the radiator using your hand – it should be hot in all areas of it. If its cold in on side and very hot in another side – you have got a plugged radiator and you need to clean it.
Old Apr 10, 2008 | 11:02 AM
rst230bhp's Avatar
rst230bhp
u might aswell bleed the system aswell start the car with the header tank cap off, leave car running till fan kicks give the hoses a few squeezes should see loads of air bubbles in the header tanks. hope you get it sorted
Old Apr 10, 2008 | 11:35 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I would just put a new good quality standard rad in it.
Old Apr 10, 2008 | 04:07 PM
bad boy rs's Avatar
bad boy rs
Do you recomend allow rads christian or is it best to stick standard ?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
