s2 wont start
help needed with my s2 ive just put it all back together and tried to start it, it coughed and splutered and ran for about 30 seconds then stalled and wouldnt re start it has a spark but doesnt sem to be getting fuel to the injectors ive cracked off the main fuel feed into the metering head and there is fuel there, ive tried another metering head and didnt start but dont no if either of the metering heads are any good any help please
Is there enough fuel in the tank ? cause i have just put mines back together after restoring underneath and put a jiffy can of fuel in and that wasnt enough to get the system pressurised and fuel to get it running
it does sound like the metering head cos when you turn the ignition on and the oumo primes ive cracked off the main feed and there is fuel under pressure but if i crack off one of the injector pipes on the top only a very small amount of fuel if any appers. the fuel has sat in the tank for ages i think, maybe its gone off?? and i need to flush the system. anybody else had these problems
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
