Rover 200 Starting problem
Hi all,
Obviously this is a Ford Forum but there seems to be so many people on here who are helpful with all sorts of different makes and models I thought I'd give it a go.
I have just bought myself a Rover 200 on a T plate which needed the clutch replacing. The car ran fine before taking the gearbox off.
Now that everything's back together the car fires but will not start. There is fuel and the spark is very good but the car just will not run.
Any help or suggestions would be appreciated.
Dave
Dave
Hi all,
Dave
Dave
You didn't change the flywheel did you???
CabrioTurbo
Aug 1, 2015 11:04 AM
