Map sensor INFO NEEDED please help
Old Oct 22, 2004 | 01:41 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default Map sensor INFO NEEDED please help
Has anyone got the DATASHEET for Magneti Marelli's Map sensors, or know anywhere i can find the information please.
I need to know.
The Volt range of the 3bar map sensor compared to pressure.
There are more than one type of 3bar map sensor which shows different readings @ different pressure.
The types are:-
APS 05/01
SPA 05/01
If any more please let me know.
Regards
Jano
Old Oct 22, 2004 | 01:46 PM
Jim Galbally's Avatar
Jim Galbally
yes thanks
Old Oct 22, 2004 | 01:57 PM
Dave Henshall's Avatar
Dave Henshall
email me and il reply back with them , got the genuine marelli pdf files on both
Old Oct 22, 2004 | 01:59 PM
Dave Henshall
incidently the difference between the 2 is nothing IIRC, one is just the new version of the old original one - same characteristics.
oh yeh,, dave.henshall@astrazeneca.com
Old Oct 22, 2004 | 02:31 PM
Sexy-RS's Avatar
Sexy-RS
I will tell you the secret formula if you give us a good price jano
https://passionford.com/forum/viewtopic.php?t=80559
Old Oct 22, 2004 | 02:42 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its in the Tech section
But il tell you now that the APS and SPA are exactly the same part.. one being a slightly different grey to the last one
Old Oct 22, 2004 | 08:04 PM
Versus_Creations
Ask me a question!
Any reason i get different voltages from the two types of sensors? Only slight difference but its enough?
yes thanks
What was the point in that
Old Oct 22, 2004 | 08:45 PM
ECU Monitor Enthusiast
Jano_OddKidd, Any reason i get different voltages from the two types of sensors? Only slight difference but its enough?
Its called manufacturing tolerances or one of the sensors is faulty !
If you get 10 brand new 3 bar sensors you WILL get different readings for nearly
all of them depending on the accuracy and resolution of the measuring
device reading the voltage.
ECU's work internally by averaging these signals to reduce such errors.
Old Oct 22, 2004 | 09:39 PM
Versus_Creations
Ask me a question!
Originally Posted by SECS
Jano_OddKiddOnly slight difference but its enough?
If you get 10 brand new 3 bar sensors you WILL get different readings for nearly all of them
So in this case:-
if i had a visual interface (Pectel Monitor) which has been designed with a certain map sensor and programed to its stated volatge signals. If i change the map sensor to another one which has slightly different signals will the visual interface be correct.
The reason i ask is because @ idle it does change bst pressure. So if it averages out in the ECU this wouldn't happen would it? Unless the figures were far out and the averages add up different.
Old Oct 22, 2004 | 09:59 PM
Jano_OddKidd, This depends on the ecu/chip, some use MAP and TPS to
estimate load at idle which stabilises fuel delivery in a pulsing manifold and to
some extend it ignores the map sensor input for a portion of time.
It is a fact of electronics and mechanics for that matter,
all components are built to a tolerance and when a part is made of many
such components, the tollerances add up differently.
Map sensors are accurate enough for the job they do but their range
will drift with age/temperature and use.
These are not laser trimmed during production otherwise they would cost
10 times as much.
Remember, It is a mass produced part after all and built to a cost.
Old Oct 23, 2004 | 08:51 AM
GARETH T's Avatar
GARETH T
SECS, sometimes i think you know what your on about
Old Oct 23, 2004 | 08:54 AM
Versus_Creations
Ask me a question!
Thanks for your time Simon.
manuel boeckx
13
Oct 3, 2015 02:29 PM
cos elle
Sep 1, 2015 06:48 PM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
