PassionRover 1.8 VVT cam timing?
Old Apr 5, 2008 | 01:57 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Default PassionRover 1.8 VVT cam timing?
head gasket went on my mates Rover 220 coupe, can't seam to find a Haynes for this model so before i take it apart does anyone know any links to were i can find info on this engine including torque setting, timing etc etc.
Old Apr 5, 2008 | 02:03 PM
Spiky's Avatar
Spiky
mr hadland
Old Apr 5, 2008 | 02:12 PM
Johnny Knoxville
Come on martin
Old Apr 5, 2008 | 04:03 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
no way didnt knoe they put that engine in the coupes
Old Apr 5, 2008 | 04:22 PM
vinnyvangough's Avatar
vinnyvangough
Thought the 1.8 vvt lump was in the bubble shaped 200 series not in the coupe
Old Apr 5, 2008 | 05:15 PM
James's Avatar
James
just the same as a normal k series iirc, except you have the other belt on the other end to change. just remove one of the cam sprockets, pop the belt on and put it back on the cam.
Old Apr 5, 2008 | 05:31 PM
Stampy's Avatar
Stampy
No torque settings to hand, but here's the timings:
Old Apr 5, 2008 | 05:38 PM
Stampy's Avatar
Stampy
Just found the Torque settings aswell
Engine
Nm Lb/ft
Camshaft cover bolts 9 7
Camshaft gear bolt
8mm bolt
10mm bolt
33
65
24
48
Crankshaft pulley bolt 205 151
Cylinder head bolts
tighten progressively
1st stage
2nd stage
3rd stage
20
180 degrees
180 degrees
15
180 degrees
180 degrees
Flywheel to crankshaft bolks 85 63
Oil Pressure switch 12 9
Sump bolts 10 7
Sump to gearbox bolts 45 33
Sump drain plug 25 18
Tensioner pulley backplate bolt 10 7
Tensioner pulley Allen screw 45 33
Timing belt, front top cover 9 7
Timing belt, front lower cover 9 7
Timing belt, rear cover to coolant pump 10 7
Scuse the poor formatting!
Old Apr 5, 2008 | 07:36 PM
AlexF's Avatar
AlexF
220 coupe is not a k-series lump.....
Old Apr 5, 2008 | 07:48 PM
Stampy's Avatar
Stampy
The later models did indeed have a K fitted
IIRC the earlier ones had Honda B/D series and the turbos the T series.
Old Apr 5, 2008 | 08:59 PM
Nash's Avatar
Nash
Cake lover!
Spot on.
1.8 VVC were the very last Coupes, also had MK3 dash in them aswell.
Old Apr 5, 2008 | 09:13 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
What exactly do you need to know??
Old Apr 5, 2008 | 11:01 PM
RWD Pete's Avatar
RWD Pete
220....thats a VVT?
Old Apr 5, 2008 | 11:02 PM
L33 BYT's Avatar
L33 BYT
Originally Posted by RWD Pete
220....thats a VVT?
?? Its not, Its a T-series, Which comes in NA and turbo models.
Old Apr 5, 2008 | 11:03 PM
RWD Pete's Avatar
RWD Pete
Big old heavy lump
Old Apr 6, 2008 | 12:21 AM
Johnny Knoxville
Where do all the timing marks have to be before i take the head off?
What to look out for?
Any tips will help martin
Pics and link will help also
Old Apr 6, 2008 | 12:23 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
just a hint, leave the vvc units and the cams in the cam housing... the units are pretensioned and can be an arse if they fall apart!
Old Apr 6, 2008 | 08:51 AM
AlexF's Avatar
AlexF
my understanding was the 220 was a 2 litre... which is the old T-series.
Alex
Old Apr 6, 2008 | 09:04 AM
Johnny Knoxville
Alex
my mistake its a 218vvt
anyway found what i need to know on here http://forums.mg-rover.org/
Old Apr 6, 2008 | 10:04 AM
It's Czech Mate's Avatar
It's Czech Mate
Stampy...long time no see......
Old Apr 6, 2008 | 06:41 PM
Stampy's Avatar
Stampy
Hello.............are you an ex ZSOC member too?
*edit* Aha, just seen your email address - Matt "Windup Merchant" RS1600i.
How you doing mate?
Old Apr 6, 2008 | 07:10 PM
It's Czech Mate
How you doing mate?
Oi Oi...still got the mgf?
Old Apr 6, 2008 | 07:43 PM
Stampy's Avatar
Stampy
Yeah, been trying to punt it off and come back to the blue oval (fancy something with a turbo these days ) but no success as yet.
You still running the ZS?
RUBY123
Oct 22, 2023 12:04 PM
Porplus12
Sep 10, 2015 07:20 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
