New crank!
Looks like i might be needing a new crank due to heavy scoring the engineer thinks there might no be enough meat left on it to regrind!
Does anyone know the best place to get one?
Thanks!
Thanks!
ive got a crank n th garage out my s2,aint needed now as im going down th zetec route mate has had it at his work and there no wear on it and will use standard shells,
make an offer for it mate
B1G RST, how do you know there is no wear have you had it measured? But yeah i'll probably have it of you if your happy to post it, and for the right price of course
Does anyone know if you can change the crank without taking the engine out? Haynes says you cant
yes its been measure by my mate who works at moss morran,i dnt think u wil be able to do it without it being out the car as the flywheels inside the gear box bell ousing therefore dont think ul b able to get in, where bouts are ya mate ?
If i drop the gearbox out I will be able to remove the fly, it's the oil pump side i'm not sure about.
I'm in Sudbury, Suffolk, mate. I use www.interparcel.com would be about Ł8.30 for anything up to 20kg, i've even sent gearbox's for that price all bubble wrapped up!
if your taking the gearbox out its only one more mount n the engines out,wel if u make an offer and arrange tht couriur id b more than happy to buble wrap it mate
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
