pinto engine trouble
Old Apr 2, 2008 | 06:36 PM
tomathy2003's Avatar
tomathy2003
Angry pinto engine trouble
i took the rocker cover off and found a couple of small shards of metal!
i then took the sump off and found more shards in there!!
the engine was leaking oil into the piston chambers and burning the oil!!
what cld the shards be, im thinking piston ring or seal off sumthing???
Old Apr 3, 2008 | 06:39 AM
Piccies ?
Won't be rings if shards as they are really brittle material, but it clearly needs to come apart anyway.
Old Apr 3, 2008 | 11:37 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
could be anything, gravity generally means things end up in the sump. it could be bearing material, or even where its had machining done before and it hasn't been cleaned properly before being put together!
big_Rad
Sep 15, 2017 09:36 AM
nicos#29
17
Sep 7, 2015 05:32 AM
Ben26
Aug 27, 2015 08:56 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
