overfuelling
Old Apr 1, 2008 | 06:50 PM
RS SHAUN's Avatar
RS SHAUN
Default overfuelling
been trying to sort my 2wd saph out for a while now, changed all sensors, its running better got it down to 5% CO, but we cant get any adjustment at all on the ecu CO screw, is this a ecu fault?
Old Apr 1, 2008 | 07:18 PM
lamb chops's Avatar
lamb chops
hmm sounds like it, this should ajust CO quite a bit when you have it on the meter
Old Apr 1, 2008 | 07:20 PM
RS SHAUN's Avatar
RS SHAUN
it doesnt move at all mate
Old Apr 1, 2008 | 07:21 PM
lamb chops's Avatar
lamb chops
What ECU is it L6 or L8? sounds like you will have to take it out and pop the cover off and see why its not moving..
Old Apr 1, 2008 | 07:24 PM
RS SHAUN's Avatar
RS SHAUN
its an L6 mate, had a look inside and the screw is connected inside
Old Apr 1, 2008 | 07:28 PM
lamb chops's Avatar
lamb chops
It may be easyer to get another.. it should turn two or three complete revolutions i think..
Old Apr 1, 2008 | 07:56 PM
RS SHAUN's Avatar
RS SHAUN
the screw just spins and spins, and the CO doesnt move on the meter!
Old Apr 2, 2008 | 06:56 AM
The screw does just turn and turn, and goes past base and back etc.
The fact that it is not adjusting the co is of course as you say wrong, I would as said have a look inside to see if the trim pot is damaged, or become broken disconnected.
The screw does not have a stop as such and will just turn.
radiant red
43
Oct 26, 2006 07:36 PM
robbyridz
Oct 20, 2006 04:43 PM
bunjeeman
Sep 10, 2006 10:39 AM
timrud
Jun 20, 2006 09:05 PM
xr4x4rs
Sep 5, 2005 12:44 AM
