Fitting a zetec into a mk2 xr2
would anyone be up for it? im after a 2.0 silvertop or the 130ps 1.8. i'll travel to get it done and will supply the engine and conversion bits.
any interest?
any interest?
its relativly easy mate, i take it you allready know about having to sawp various bits from the 1.8 engine to run the 2l?
you will have to modify the cvh engine mount by welding an extra lug onto it and cutting off the lower one and use a tank with a swirl pot and obivioulsy an injection pump. should take you a weekend max if you have eveything you need all set up in front of you
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
