small turbo cos map sensor
Old Mar 29, 2008 | 10:18 AM
rapidonion's Avatar
rapidonion
Default small turbo cos map sensor
what is the max boost input for the map sensor on the small turbo escort cossie its the ford frequency based type is it 14.5 psi like the fiesta OFAC one??
Old Mar 29, 2008 | 01:42 PM
sailorbob's Avatar
sailorbob
2.5 bar
Old Mar 29, 2008 | 04:52 PM
Roughly 1.5 BAR, as it reads up to 1 bar negative(vacuum) so swings the other way to 2.5BAR absolute, meaning 1.5 BAR positive.
These sensors often have a overead capability, sometimes by a lot, but not sure how much with this one.
1 Bar = 14.5038 PSI.
Old Mar 29, 2008 | 06:01 PM
rapidonion's Avatar
rapidonion
Default psi
so whats the max psi i can run through my car with the standard sensor is 18 psi ok?
im guessing that there are no upgrades for the frequency based sensors unlike with the webber type?
cheers in advance all!!!
Old Mar 30, 2008 | 06:02 AM
I am not clued up on these, and would seek the opinion of some like GGR/Collins.
Old Mar 30, 2008 | 08:45 AM
sailorbob's Avatar
sailorbob
I think they max out at about 26 psi of boost but your limitation will be what ever ecu you are running.
Old Mar 30, 2008 | 09:29 AM
rapidonion's Avatar
rapidonion
Smile map
cheers again all
Old Apr 1, 2008 | 03:14 PM
joffy's Avatar
joffy
SLOW LEARNER
it will read 1 1/2 bar of boost pressure, as atmosphere is already one bar, this plus the 1.5 bar equals your 2.5 bar?? so theoretically 21.75psi (ish)
Old Apr 1, 2008 | 05:08 PM
rapidonion's Avatar
rapidonion
Default cheers
thanks mate
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
costina
18
Aug 25, 2015 06:02 PM
kosienutter
31
Aug 22, 2015 09:55 AM
IAN RS2k
Aug 18, 2015 07:51 PM
