petrol transit engine problems
Old Mar 25, 2008 | 09:58 PM
tomathy2003's Avatar
tomathy2003
Exclamation petrol transit engine problems
hi guys, new to this forum and in desperate need of help and advice!
i have a 1993 transit executive petrol 2ltr, it seems to be burning oil, also keeps covering spark plugs in oil so it keeps missfiring! is this pistons rings gone??
also if this is took much work for me to repair what replacement engine(s) could i get??
thank you very much!!
Old Mar 26, 2008 | 01:51 AM
MrMPuk's Avatar
MrMPuk
Pinto engine, could be valve stem oil seals.
Old Mar 26, 2008 | 06:38 AM
If the plugs are getting covered in oil fix the leak, most likely the rocker cover, DON'T overtighten as this will distort the cover.
As said stem seals go first, but depending on mileage/use/history it could also be rings/bores.
Old Mar 27, 2008 | 04:36 AM
MrMPuk's Avatar
MrMPuk
I would think he ment the ends of the plugs in the engine.
Old Mar 27, 2008 | 04:36 PM
tomathy2003
yeh thats wot i mean, the inside end of the plugs!!
if i replaced the engine wld it matter if its a 185 or 205 block?? i dnt know wots in there now?? its a j-reg!!
Old Mar 28, 2008 | 04:45 AM
MrMPuk's Avatar
MrMPuk
Think the Transit will be 205
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
RUBY123
Aug 14, 2015 09:26 PM
Mark RS
14
Aug 11, 2015 11:45 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
