1.8 engine with 1.6 box
Old Mar 24, 2008 | 12:07 AM
TJ Reynolds's Avatar
TJ Reynolds
Default 1.8 engine with 1.6 box
Will a 1.8 mondeo engine be ok on a 1.6 fez box or will i need both engine and gearbox?? -my engine seized earlier, and thought this was the practical solution.
Thanks luke
Old Mar 24, 2008 | 08:12 AM
Should be fine, don't know if all the enginey other bits will fit ie exhaust etc.
Old Mar 25, 2008 | 02:08 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
If you were to use the Mondy gearbox you'd probably have to change the gear linkage too as I believe they're all the lift up reverse type. Should be fine with the Fez box.
Old Mar 25, 2008 | 04:03 PM
TJ Reynolds
cheers peeps
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Dubs44
Aug 21, 2015 02:42 PM
knight19770
Aug 4, 2015 12:36 PM
