non turbo block
Old Mar 23, 2008 | 11:12 PM
RS_JASE's Avatar
RS_JASE
Default non turbo block
just bought meself a S1, with a buggard engine.....
i was wondering if i can use the bottom end of a non turbo 1600 cvh, as therer seems to be more of these around.
if anyone can help me it would be much appriciated
Old Mar 24, 2008 | 09:18 AM
XR2's Avatar
XR2
Nope. Don't have the connectors for turbo oil feed. Pistons also were different. Not sure about the conrods...
Old Mar 24, 2008 | 09:20 AM
Mr.T's Avatar
Mr.T
Don't know what you want but if you want to convert a non turbo to turbo with turbo pistons yes it can just get the oil feed from your RSt engine and make a oil return in the sump and place the turbo pistons in it.
Old Mar 24, 2008 | 08:01 PM
MarkN's Avatar
MarkN
I have done it - piece of piss to get the hole for the drain drilled in the block.
I got the CPS hole drilled in mine at the same time to allow me to run Fiest Turbo EFi...
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
mint_s2
Sep 2, 2015 08:58 AM
