Sapphire 4x4 Running Problem!!!!!!!
Old Mar 22, 2008 | 03:02 PM
cos4x4cos's Avatar
cos4x4cos
Default Sapphire 4x4 Running Problem!!!!!!!
Hi, Having A Problem With My Car Yet Again!!!
Car Starts Up Fine And Idles Okay. When I Go To Rev It Up It Only Seems To Want To Rev To 2000rpm And No More. Any Ideas Please??????????
THANKS.
Old Mar 22, 2008 | 08:39 PM
NAKRS's Avatar
NAKRS
You Best Check The Distributor Phase Sensor
While You You At It Check The Plugs Arent Dead And Very Important That There Are No Cracks In The Porcelain Of The Plugs..........
Old Mar 22, 2008 | 09:25 PM
cos4x4cos's Avatar
cos4x4cos
I have just changed the plugs. will check the leads. How difficult is it to change the phase sensor? does it need to be gapped or is it already set if i buy a new one? thanks.
Old Mar 22, 2008 | 10:49 PM
NAKRS's Avatar
NAKRS
Its A Piece A Cake Mate
Open Up The Dizzy Cap Yeah Unplug And Unscrew The Old 1 And Put The New 1 In Place Take Note If The Old 1 Is Corroded ...... Good Luck
Oh And In Future If She Take A Long Time To Start They Flood Very Easily And Kills The Plugs One Way Is To To Disconnect The Pump Under The Boot Swing It Till It Starts And Then Quickly Push It Back Again Chow
Old Mar 22, 2008 | 10:50 PM
NAKRS's Avatar
NAKRS
Oh There Is No Need To Set Or Adjust The Phase Sensor Just A Straight Swop
Old Mar 23, 2008 | 08:35 AM
Don't listen to the above crap.
The phase sensor has a gap, 0.2mm to 0.3mm.
If it doesn't start immediately it needs looking at not bodging by disconnecting pump etc.
By all means look at the PHASE sensor, the earlt ones had crap insulation on the wires which basically falls off, later ones have 1 RED, 1 BLUE wire, the RED wire which is uppermost on the sensor goes to the point on the dizzy body through connector nearest to it.
Parts can be got from Matt Lewis 01922 692424, about £20 from memory.
This is accedemic though as NOT your problem, if it were it would not start and idle.
Does the car belch black soot or anything when trying to rev it ?, does it do no revving all the timeor just when hot/cold ?
What leads are you using, look for any broken disconnected pipes for air leaks.
jason_nike
Aug 18, 2019 10:53 AM
big_Rad
Sep 15, 2017 09:36 AM
saph in dorset
Aug 14, 2015 10:10 AM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
