What AF for max power??
Old Mar 20, 2008 | 05:49 PM
Willem's Avatar
Willem
Default What AF for max power??
As in title, what's the best AFR for maximum reliable power??
All answers welcome, with motivation please
Old Mar 20, 2008 | 09:46 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
14.7:1 /15:1 gives the best burn, but thats just because it leaves the least percentage of unburnt fuel after combustion. wether theres a different ratio for power i dont know, but you really want to be looking for 15 to 1
Old Mar 20, 2008 | 09:48 PM
Willem's Avatar
Willem
15:1 is lean, normal combustion engines are about 12,5-13 on full load, but I'd like to know when you can get the most power out of it....
Old Mar 21, 2008 | 12:05 AM
JesseT's Avatar
JesseT
An RST makes the most power at around 12.5:1. 15:1 for economy at cruise. 11:1 for reliability at big boost.
Old Mar 21, 2008 | 08:47 AM
sailorbob's Avatar
sailorbob
There is not a fixed A/F ratio for maximum power as every engine behaves differently. You typically find that maximum power is richer than stoichiometric but you need to run even richer than this for cooling.
Old Mar 21, 2008 | 10:46 AM
Jasesapphy's Avatar
Jasesapphy
running a turbo car at those numbers above will be a melted engine, on a turbo car you want to be in the 11s on boost
Old Mar 24, 2008 | 01:16 PM
Stu @ M Developments's Avatar
PassionFords Creator
Absolutely correct. However, aim to start with 12.5:1 as this is the figure that gives the best results on the widest array of engines. Be aware though that max power is NOT what you should be aiming for when mapping. But it at least answers your question.
Old Mar 24, 2008 | 07:09 PM
Willem's Avatar
Willem
Thnx guys, this gives a little undertanding
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
SMILER258
Sep 28, 2015 09:04 AM
