rs turbo Kjet
Old Mar 20, 2008 | 01:29 PM
original's Avatar
original
Default rs turbo Kjet
hello all
could someone explain to me how the kjet system works on the escort rs turbo. I have a 16V golf that uses a metering unit and mechanical injectors for fuel but runs an ignition control unit for the spark.
I've always understood that rs turbos could be tuned on the rolling roads but what is actually adjusted/do they have any form of map?? - I know all about the efi fiesta setup just little about the mfi
any help on understanding them would be great, always trying to learn more stuff and the best way to find out is to ask the people that mess about with them the most!!
Paul
Old Mar 20, 2008 | 02:06 PM
velocity's Avatar
velocity
it could take a while to do but the rs turbo runs a KE jetronic system
it is very similar to the K jetronic which has no ecu.
you can map a KE system because the metering valve has and extra unit attached called a pressure actuator that is ecu controled to modify fuel mixtures across the range, the k jetronic metering valve doesnt
and the ignition sysem also has a ecu to change the ignition map.
thats as simple as it gets.
Old Mar 21, 2008 | 12:02 AM
JesseT's Avatar
JesseT
The KE has a form of a primitive "ECU", but it has no processor, memory or a map. Just some resistors, capasitors and transistors.
Old Mar 21, 2008 | 08:12 AM
radiant red's Avatar
radiant red
its a system that uses fuel preasure to control fuel quantity. Via the position of the airflow meter.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
