help setting my boost
Old Mar 17, 2008 | 09:51 PM
Tev's Avatar
Tev
Default help setting my boost
right i need help with setting my actuator on my car,
basically i had my car set up bout 4 months ago n everythings been sweet (cheers stu) but the other week i noticed i was 2 psi down on boost
n last week i dropped another psi, so after a couple of checks i have come 2 the conclusion that the spring has gone weak in my actuator,
long story short ive just orderd a collins actuator,how do i go bout setting it up?
i realise it will b a process of doing test on the road but do i extend the rod 2 increase or decrease boot?
and can i measure the rod on the old actuator 2 get a rough idea of how long the rod needs 2 be?
cheers jay
Old Mar 18, 2008 | 08:12 AM
Always remember LL, Lengthen(rod) to Lessen boost.
That's the easy way I remember it!!
Set it so that it reads the same as before boost wise, go up the road in fourth, boot it and see what the max boost is and adjust as necessary.
Old Mar 18, 2008 | 11:42 AM
Tev's Avatar
Tev
cheers fella
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
