rs2000 non start?
Old Mar 16, 2008 | 06:10 AM
fast_ford_uk's Avatar
fast_ford_uk
Unhappy rs2000 non start?
hello guys, right my rs2000 will only start if you hold open the throttle fully but then gives one rev and dies (like when an engine is flooded) before it would idle but as soon as you touched the throttle it would die also. my first thoughts were a sticking injector causing over fueling, replaced injectors still the same problem.
a couple of times it would chuck so much fuel down the bores it would stop the engine from turning over
any one got any ideas?
Old Mar 16, 2008 | 06:12 AM
fast_ford_uk
is there some sort of fuel pressure regulator? if so wheres it too?
Old Mar 16, 2008 | 12:54 PM
I would be looking at the TPS first take a few readings open and closed.
Old Mar 19, 2008 | 05:07 PM
fast_ford_uk
nope swapped the sensor for another one and still nothing. what controls the fuel pressure the pump?
Old Mar 24, 2008 | 11:36 AM
fast_ford_uk
no one?
Old Mar 25, 2008 | 05:57 AM
stevecossy's Avatar
stevecossy
There is a press regulator on the end of the fuel rail buddy, left hand side as ya look into engine bay. good luck
Old Mar 25, 2008 | 10:03 PM
COLEYST200's Avatar
COLEYST200
Its a shame you so fare away from me as i have RS2000 MOTOR siting in the corner in the garage doing nuthing and it was a runner when we tuck it out of the car
Old Mar 28, 2008 | 07:05 PM
fast_ford_uk
hmm, not that far really, ive got a spare engine but havent all the ancillary's ect, cant work out whats causing the mass over fueling. any one no what sensors could cause this?
Old Mar 31, 2008 | 11:47 AM
fast_ford_uk
update; have replaced the following with no luck, cps, manifold temp sensor, cts, coil packs
stuck were to go next?????
Old Apr 11, 2008 | 11:40 AM
rs2kmk5's Avatar
rs2kmk5
Have you taken the fuel rail off and inspected the seals between the rail and the head - this is a known fault, and ford dont offer replacement seals - in their infinite wisdom, they were only ever available as part of a complete inlet manifold (along with injectors etc) - for around #850!!!
A trick some people have used with varying degrees of success is to remove the seals, soak them in boiling water,freeze them, then repeat a few times - and sometimes they'll revert back to their original shape. Job done.
Remember to depressurize the fuel rail before you remove it - just pull the relevant fuse for the fuel pump, and let her idle til she stops.
Let us know how you get on, and hope that helps?
Old Apr 11, 2008 | 11:56 AM
sheerline's Avatar
sheerline
has the battery box rotted , the batterys fill up with rain leak acid into pass footwell directly below the battey box is the ecu
Old Apr 12, 2008 | 02:20 PM
fonfe's Avatar
fonfe
lambada sensors will be telling the ecu weather the mixture used is rich or lean so they could affect it. be sure to check you throttle postion sensor wirse fully though. i just rebuilt an i4 lump and all was totally fine apart from the wires goign to the coilpack for cylinder 1 and 3, they had compleatly fallen apart inside the heat insulation. may be worth you checking the wires from the plug to the ecu plug with a muiltimeter for continuity
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
