efi help
Old Mar 15, 2008 | 07:46 PM
paul66 turbo's Avatar
paul66 turbo
Talking efi help
hi chaps in doing the efi route ive got a late erst engine with crank sensor a frst flywheel and ive got a 90 spec efi xr3i for bits im taking the hole loom out to put into my turbo
just a few questions what ecu do i use?? ive got a frst inlet to go on will the loom plug into this ok?? can i use the xr3i head??
what other bits will i need injectors sensors ect any help will be great
Old Mar 15, 2008 | 08:24 PM
philyS2's Avatar
philyS2
Im in the middle of this too,if its a turbo car ive been told you need the fiesta rs turbo engine loom(ofab) and ecu
Old Mar 15, 2008 | 08:34 PM
picky775's Avatar
picky775
you can use the frst ofac or ofab ecu.if you use the ofac you need the ofac map sensor to go with it it looks like a standard efi one but is a bit smaller at the top.If you use ofab then you need the ofab map sensor its more like a triangle iirc with the hose connection in the middle were as ofac map has the hose underneath.Xr3i loom from an efi will plug straight into frst engine loom if you have any problems look on rsbible.co.uk it tells you the complete conversion.hope this helps
Old Mar 15, 2008 | 08:49 PM
paul66 turbo
Default efi
ok thats great thanks, with out sounding stupid do i need the frst engine loom or can i run the 3i loom with a frst ecu???
Old Mar 15, 2008 | 08:53 PM
picky775's Avatar
picky775
you can use the xr3i engine loom but you need to change two of the plugs,charge air temp sensor and water temp sensor on back of inlet.On 3i's there a wierd round plug but you need the sensors from a frst witch are square heads mate.
Old Mar 15, 2008 | 08:56 PM
paul66 turbo
ok mate have you done this conversion then?? what did you do to your car and what problems did you have thanks for the help
Old Mar 15, 2008 | 09:01 PM
picky775's Avatar
picky775
yeh ive done the conversion,i tried both ofac and ofab ecus and map sensors but had lots of problems so i ended up gettin gotech management and first off had problems with that but turned out to be week fuel pressure,there was a split in a petrol hose in the tank that comes off the pump fixed that and was fine
Old Mar 15, 2008 | 09:12 PM
paul66 turbo
Default efi
ive got an efi headand both 3i and frst inlets can i use either of these with the 3i loom to get it up and running?
Old Mar 15, 2008 | 09:26 PM
picky775's Avatar
picky775
you can use either inlet but again you need to swap the 2 sensors over to frst ones mate
Old Mar 15, 2008 | 09:46 PM
paul66 turbo
Default efi
ok mate thanks for your help
Old Mar 16, 2008 | 11:36 AM
moesin2005's Avatar
moesin2005
i used the 3i head on mine been told on hear that all efi heads are the same plus you will need the efi throttle cable but never heard about swaping the water sensor will have to look in to that.plus some peaple say you need a surpresor if you run ofab but my mate has done this conversion before and said it ran fine without one
Old Mar 16, 2008 | 11:48 AM
picky775's Avatar
picky775
The water temp sensor and charge air sensor read differently on 3i and frst it will run with either but if you want it right then swap them for frst ones then you know you can increase boost etc without any issues with sensors.As for the surpresor it will run fine without it but it WILL do damage in the long run so if you are going the ofab route then get the surpresor,If you dont need it then it wouldnt be there in the first place,its there for a reason so get one.
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
