Efi Conversion plate
Old Mar 15, 2008 | 07:34 AM
philyS2's Avatar
philyS2
Default Efi Conversion plate
Do the efi inlet manifold conversion plates work or are they just a load of crap,im collecting bits for my efi conversion but i aint got an efi head yet but i can get hold ofd the conversion plate.just wanna know wot ppl think ov them first
Old Mar 15, 2008 | 09:19 AM
moesin2005's Avatar
moesin2005
they can be quite dear though where as u might be lucky and get a cheap head also it think all efi heads are the same not like the mfi ones
Old Mar 15, 2008 | 06:03 PM
bad boy rs's Avatar
bad boy rs
I had one on mine before i got my efi head. It done its job, got mine from janno, 60quid if i remember.
Old Mar 15, 2008 | 06:51 PM
XR2's Avatar
XR2
Your injectors will spray the petrol onto the metal of the inlet ports. Will loose power especially on low revs. Get yourself a EFI head...
Old Mar 15, 2008 | 08:26 PM
philyS2's Avatar
philyS2
cheers lads,ill just have to get a efi head,any 1 got the suppresor thats on the fiesta rs loom?
Old Mar 15, 2008 | 09:18 PM
blan77's Avatar
blan77
Thumbs down
my friend just got his conversion plate off ODD KID this week after waiting 3 or 4 wks for delivery, it looks like a piece of SHIT.....
i,ll get him to post piccys of it on here
Old Mar 16, 2008 | 11:38 AM
moesin2005's Avatar
moesin2005
my mate said his ran no problem with no suppresor but thats up to you and it is only sposed to be used on the ofab ecu
Old Mar 16, 2008 | 02:51 PM
philyS2's Avatar
philyS2
Yeh thats wot ive got ofab loom and i need a ofab ecu
Old Mar 16, 2008 | 04:13 PM
pauls.ego's Avatar
pauls.ego
after waiting 4 weeks of being told its at the machinist and its in the post this arrived in a bag,the only bits that line up are the stud holes .going to get the dremmel out and finish it my self cant wait another 4 weeks for him to sort it out, would not recommend him to my worst enemy,service =sh*t,after sales care=sh*t delivery =sh*t and for any one sticking up for him i was told it was posted by the second week got delivery proof it was posted the day before it arrived .he could not and would not give proof of posting for the full 4 weeks this was my first and last dealing with him or his company.... very unprofessional.
(sorry for any spelling mistakes)
how it arrived
machining does not match his own professionally drawn lines
how it looks mated up
my mates and every other one i have seen
odd kidds own picture of his own product
looks the same,i dont think so
like i said wont be sendind it back me and my mates can mod it to fit properly, dont wont anything to do with him,only posting this to warn others of the quality of his products
Old Mar 16, 2008 | 04:21 PM
pauls.ego's Avatar
pauls.ego
how it arrived
machining does not match his own professsionally drawn lines
Old Mar 16, 2008 | 04:27 PM
Mr.T's Avatar
Mr.T
Thats bad. Better of with buying an efi head.
Old Mar 16, 2008 | 04:29 PM
Red16's Avatar
Red16
my mates midway through zetec turbo'ing his Escort, he's decided not to use the ofab stuff and to go for Emerald management, which means he now has the ofab ecu spare... he may also have an efi head as he was going to go zvh at first... he's in south shields so nice n local to you, drop him a pm if youre interested... his usernames R6Franky
Old Mar 16, 2008 | 05:36 PM
steven botes's Avatar
steven botes
you dont need to use this adaptor. if you have a close look at the efi manifold with the injectors on place , you will see that the injectors are quite far back and dont get very close to the head. using a efi gasket from ford , mark the non efi head and carefully remove some meat where the injectors go . you should end up with about 3mm between the inside of the port and the edge of the face on the head - my 89 xr3i runs fine with this modification when i used its head for the turbo. i ran my sidedraught motor with only about 2mm between the port and the edge of the mating face on the head , and this motor saw 2 bar without a problem. looks to me that you will now have to do double work on the match porting and have twice the hassle with gasket blowing
Old Mar 16, 2008 | 05:53 PM
philyS2's Avatar
philyS2
Cheers red16i could get my sis to pick owt up for us as she lives in southshields(has a right geordie accent now)
Old Mar 17, 2008 | 06:01 AM
Red16's Avatar
Red16
he's got efi inlet and a few other bits too
Old Mar 17, 2008 | 06:34 AM
philyS2's Avatar
philyS2
Ive got the efi inlet,and ofab loom just need the head,ecu andfly wheel
Old Mar 17, 2008 | 06:43 PM
moesin2005's Avatar
moesin2005
on mine i use the ofab ecu on a xr3i loom you need to swap the plug for the map sensor which has to be mounted with the hose faceing downwards i used a cosworth mounting bracket and fixed it to the heater box plus you have to swap some of the wires on the ecu plug try rs bible it tells you which ones to swap
Old Mar 18, 2008 | 08:44 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
LOL ... probably useless information but so as you're aware; the top adapter plate was made by myself - the blending on the ports is quite a specific shape, one that I recognise instantly.
Funny thing is, some time ago Jano accused me of copying his idea ... I think its safe to say my adapter plate is certainly NOT a direct copy of his.
Old Jul 6, 2011 | 12:12 AM
ThomasMK4efi's Avatar
ThomasMK4efi
is steven botes correct or not correct i like the idea of it !
Old Jul 6, 2011 | 04:48 PM
Rob_DOHC's Avatar
Rob_DOHC
I've seen it done (stevenbolts style), there are pics kicking around somwhere on the site.
IMO any adapter plate should have smaller port holes than a standard head, to be enlarged (matched) to you heads ports.
This is the risk people take when they don't get parts properly drawn up and cnc machined. The actual plate minus the cut outs doesn't look too bad, its been laser cut but like said could do with having the ports smaller, and maybe the faces cleaned up.
In Janos defence, his inlet adapter is very cheap, a decent one from ferriday will cost upwards of Ł120 i believe. I drew one up to be made but in the end it was just cheaper and easier to fit an efi head, a one off laser cut then machined would have been 70-90ish and my head was Ł50. Job Jobbed.
Rob,
Old Jul 9, 2011 | 08:27 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Pauls ego.
That is the most one sided post i have ever seen. If you had any issue you should of called me direct or emailed me etc etc.. Anything but keep quite untill it suits you to come on to a public forum slating a product.
Firstly the plate you had was the master cut, of a run of 100. For what ever reason it was lined up wrong on the jig (Not by me). You can see this due to the writing and info on the plate. Only reason you was sent this was because you was rushing me to send one out to you after i said there was nothing i could do but wait. So i didnt even get a chance to dummy it up on to a head (Here is the only mistake i made.)
Next is that if you had called me the day you found out that it didnt line up, i would of sent one out to you the next day that would line up 100%. Just like the other 99 of them i had.
The reason you waited X amount of time is that these items are not made in house and takes 3 seperate enginners to get to the finished product.
How i could be fairer than that i dont know.
As for taking it to the next step of slating me, silly talk about professional line drawing etc, my customer service etc etc is a bit below the belt. I didnt draw the lines or set the plate up in a jig.
If you had any issues i would of given a refund or sorted it out anyway i could.
I think you will find it very hard to find someone else as fair as me.
How can my customer service skills be shit if you didnt even contact me after the delivery to tell me direct about any of this.
Old Jul 9, 2011 | 11:15 AM
Rob_DOHC's Avatar
Rob_DOHC
Why three engineers Jano? I can only see two steps, laser cut and machine the injector cut out.
Rob,
Old Jul 9, 2011 | 02:38 PM
Matt carter's Avatar
Matt carter
my jano plate look just like this 6 years ago
mk3ste
Oct 17, 2021 10:09 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
