ERST Boost
Oct 19, 2004 | 06:31 PM
ERST Boost
just gettin my actuator replaced with a cossie -31. what boost can i run with standard ecu??
cheers
Oct 19, 2004 | 06:47 PM
s2 10psi s1 8-9 psi.
Oct 19, 2004 | 10:22 PM
10psi max but would recomend with winter coming up i would run 8psi!
Oct 20, 2004 | 02:47 AM
isnt 12 PSI safe? suerly with winter comming ACT's will be cooler
Oct 20, 2004 | 07:56 AM
doesnt a standard s2ecu cut out if you run it over 10psi? just something i think i heard so could be wrong...?
Oct 20, 2004 | 08:41 AM
anyone got a cheap chipped ecu?
Oct 20, 2004 | 08:59 AM
One on e-bay m8.
Oct 20, 2004 | 10:06 AM
with winter coming up you wanna run less boost cus thew cooler temps will make it boost more thats what happend to mine and i kept over boosting and killed an engine for it too!
get it chipped or run it at 8/9psi!
Oct 20, 2004 | 10:41 PM
Had mine set up to 10psi on a standard ecu and found it held 8psi didnt get any overboosting problems with mine
Oct 21, 2004 | 09:18 AM
mine only runs max boost on a cold night so id have it set up 1 or 2 psi under what you think it should run considering winter is just round the corner!
Nov 16, 2004 | 05:14 PM
wot do esrst's run standard????
Nov 16, 2004 | 05:39 PM
ksa74f/231bhp , several on ebay at the mo, even some Bayoo ones
Nov 17, 2004 | 09:16 AM
over 12psi an the boost limiter will cut in
Nov 17, 2004 | 09:20 AM
the boost limit on a standard ecu is 10psi any more that this and the boost limiter will kick in.the standard boost on a rs turbo (S2) is just a touch over 7 psi.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
