Mk 3 fiesta engine conversion
Old Mar 11, 2008 | 07:14 PM
FK Motorsport 169's Avatar
FK Motorsport 169
Default Mk 3 fiesta engine conversion
Can anybody give me any advice about putting a focus st170 engine and box in a mk 3 fiesta. engine is out ov a GR motorsport class b focus touring car. its currently at HT racing geting throttle bodies and a dry sump set up. any info would b apriciated
Old Mar 11, 2008 | 10:45 PM
rst in breaking's Avatar
rst in breaking
what do you need to know? if your just on about squeezing it in you will have to modify the engine mount, use 1800 zetec waterpump and oil pump probaly (clearance for oil pump, and so water pump meets pipe, hose will need modding as zetec water pump is i think 42mm and cvh is 32) as for gearbox if your using a bc box it will bolt up to the zetec providing you use a flywheel that works, but you could do with making some cover plates to go between block and box to cover the gaps left. i dont know if the inlet works but im guessing so as a 2.0l focus one is common on 2.0 fiesta conversions.
hope this helps
Old Mar 12, 2008 | 05:09 PM
FK Motorsport 169
thnx 4 the help m8. its getin the 6 speeder in with a lsd. its the cable change tht a thnk am guna struggle with. could a jst use the focus selector pot nd cables?
JoeyBoyden
Jan 4, 2024 02:36 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
creator
Aug 2, 2015 12:24 PM
