Why Cant I Re-use Cam Chain Tensioner On 2.0 Dohc?
Hi there I have a 1989 SIERRA SAPPHIRE 2000E, The head gasket is blowing on cyl 3, Whats the reason for not re-using the cam chain tensioner plunger, I cant see why not. Any feedback on this would be most greatfull. CheeRS for reading this post.
Yes I know that lol but if it is not that old due to recent cam chain replacement why cant i re-use the old one, seams silly to buy yet another one if the old one is not even a yr old. I.E can i re-latch the plunger or clamp the tentioner down so it dont fly out. or if it does fly out can it be re-assembled. All the ford mechanics i know cant answer that question just wondered if anyone on here can shed some light. CheeRS
I think you'll find that they're a 'use once' item. There's no telling what state it's actually in - a visual check won't tell you if it's fractured or stressed internally. If it lets go, it will make a mess!
Best to be safe than sorry with these things...
The only circumstance I would generally reset one is if it activated whilst installing.
Thanks peeps for the input on this issue, I am aware of the issues with the plunger just the one i am using was changed not so long ago when i re-new'd the chain, just think its a waste to bin the plunger as it is not that old, just wanted to know if you can re-set the piston. IANSOUTHAM if you know how or point me in the direction of resetting the plunger please point me in the right direrection if you can, the car is in bits and cant get hold of a new plunger as on back order
mk3ste
Oct 17, 2021 10:09 AM
