cozzy head thickness
Old Mar 7, 2008 | 08:54 PM
cozzy jeff's Avatar
cozzy jeff
Default cozzy head thickness
this must have bin asked before but i cant find it does anyone know the standard thickness of a cozzy head and whats the minimum thickness you can run on a turbo engine before you start to run into problems
Old Mar 7, 2008 | 09:02 PM
velocity's Avatar
velocity
according to the book, 138.68 mm is the min head thickness. you can remove (skim) 0.13 mm from the head as long as it doesnt go below 138.68. if you go below this then compression ratios become a factor.
Old Mar 8, 2008 | 07:30 AM
You can safely go below this figure, depending on how much boost/power you are running, and of course what pistons you have, you can even get thicker gaskets to raise it(head) up again if needed.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
