Wheel offset ?
Old Mar 6, 2008 | 05:52 PM
Default Wheel offset ?
Getting a new set of wheels for my cossie, various ET's available, but which is best.
All the 17" wheels are 7J, so will take 215, maybe 235(?), but what ET would be best for this.
I have coilovers so will not foul spring platforms etc(front), and should be able to go in a bit more.
Any advice/experience greatfully received, I don't mind adjusting offset with spacers etc if necessary.
Thanks
Old Mar 6, 2008 | 05:57 PM
KSA-Cossie's Avatar
KSA-Cossie
et 35 on mine m8.
Old Mar 6, 2008 | 06:46 PM
Nash's Avatar
Nash
Cake lover!
ET 33-40, you wont fit a 235 on a 7J 215 will be your max.
Old Mar 6, 2008 | 06:47 PM
costina's Avatar
costina
Live long and prosper!!
Used to Run 7j x 17 et 35 with 215's using GAZ coilovers
Paul
Old Mar 6, 2008 | 08:01 PM
fatmike's Avatar
fatmike
Hm you sure all 17s are 7j, I have just bought a set which are 17s and says they are 8j??? anyone clear that up??? Maybe its a typing error and the guy meant to write 7j
Can you fit 215's on an 8j???
It says these have an offset of 33.
Old Mar 6, 2008 | 08:27 PM
BIL N KEL's Avatar
BIL N KEL
i run 205 on 8j et33on my saff
Old Mar 6, 2008 | 08:55 PM
fatmike's Avatar
fatmike
o 205 would be even better for me, as I have 4 almost brand new ones on my older set of alloys. Are yours 17's or 18s????
Old Mar 7, 2008 | 09:56 AM
Twellsie's Avatar
Twellsie
my new ones are et38 and are spot on
Old Mar 7, 2008 | 10:14 AM
Ridgey's Avatar
Ridgey
205 sit nicely on a 7 inch rim
225 or 235 sit nicely on a 8 inch rim.
Personally don't see the point of having wider 8 inch wheels and sticking to a 205 tyre !!!!
I assume what Tabetha ment was that the wheels he is looking are are 7j, but obviously 8j are available in many makes as loads of us have them.
Old Mar 7, 2008 | 05:27 PM
Thanks for the replies, I looked at loads of wheels, wanted 8J for 235's but only in 7J the ones I looked at/wanted, getting ET28, most likely.
Just think a wider tyre is defo needed especially on 2wd, but going for some R888's, as present tyres, UNIROYAL's only lasted 2500 miles!!
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
