Help with amp needed
Old Mar 5, 2008 | 03:49 PM
crumplydazzler's Avatar
crumplydazzler
Default Help with amp needed
I am currently installing an amp in my "Y" reg focus but I need help.
Where is the easiest place to run the amp power cable from the battery, I cant see any holes that I can run the cable from the engine bay into the interior of the car...is it going to be a case of drilling a hole
Old Mar 5, 2008 | 04:20 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
You can go a couple of way.
If you go up inside the nearside wing there is a grommet in the door opening which you can route the cable through. It's a bit gash and doesn't look very good but it does the job.
Or the 'proper' way is to drill a hole in the nearside wheelarch bulkhead area underneath the 2 huge bulkhead connector plugs..........be VERY careful where you are drilling though as space is a bit tight and the loom for the fusebox runs right behind that bulkhead. The dozy twat who drilled the whole on my car forgot to check this and ended up putting a 13mm drill bit through the middle of said loom. I'm sure you can imagine the amount of work require to sort that out.
Suffice to say I wasn't best impressed!
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
muz
Aug 16, 2015 12:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
