Damaged head, can it be repaired?
Old Mar 2, 2008 | 01:58 PM
JamesR1's Avatar
JamesR1
Anybody for a brew?
Default Damaged head, can it be repaired?
Ok I have a 2.0 zetec head (Silver top) And a previous owner has managed to knacker it. It looks like spark plug or valve have come in to contact with the Piston and head even tho they are mint so must have been replaced (thats if it was a valve or plug).
Its knackered the Piston but i'm not bothered about that as its getting an over bore and new pistons.
lucky its not trashed the valve/seat, its hit the area shown in the pic, What options do i have? or is the head scrap or can that area be ported? its just inside the Fire ring so if it was to be ported out all it would do is Lower comp ratio and Increase displacement. The dinks are only about 2mm at very most so not that much alloy would need to be removed. Would this work or it be easier to find a new head.
Undamaged one
Old Mar 2, 2008 | 02:03 PM
Mr.T's Avatar
Mr.T
Yes it can. But i think its cheaper to get a "new" one.
Old Mar 2, 2008 | 06:36 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
you could repair that, but why7 not just get a new one? can gety a whole engine from a scrappy for a ton
Old Mar 2, 2008 | 07:19 PM
Moonie's Avatar
Moonie
If its just a bog standard head then just go to the scrappers and get a replacement.
If you do go down the reapir route this company are very good...
http://www.impulsedevelopments.co.uk/
Ask to speak to Adrian and tell him Chris from Volvo has put you in contact.
Old Mar 2, 2008 | 08:55 PM
Piece of cake repair this is, then just skimmed back.
tankybaby66
Feb 6, 2016 02:24 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
