How do you edit a post title
On the old PF , when you wanted to edit a post ( like a resto post to add that you have updated it ) when you clicked the edit button you could edit the title and the post , now i cant see how to edit the title ,,what am i missing ???
Pleas help this computer idiot ,lol
Click Edit on the first post, then click Go Advanced at the bottom of the grey edit area and the title should appear at the top for editing...
Only found out myself last night when I needed to update my thread!!!
I didnt & its still not letting me edit andrews focus thread
its saying this
The following errors occurred when this message was submitted:
its saying this
- You have included 24 images in your message. You are limited to using 20 images so please go back and correct the problem and then continue again.
Images include use of smilies, the vB code [img] tag and HTML <img> tags. The use of these is all subject to them being enabled by the administrator.
If I remember right, you can also do it this way:
Find the thread in the list of all threads in the room, then in the blank space directly to the right of the actual title text, double click the left button, this then puts the title into a box where you can edit it.
Obviously this only works on threads you started yourself
