Vtec Kicked in YO.....
Old Feb 28, 2008 | 08:31 AM
wirralphil's Avatar
wirralphil
Default Vtec Kicked in YO.....
shocking, wonder what the engine spec was????
Old Feb 28, 2008 | 08:33 AM
Alps Pacino's Avatar
Alps Pacino
fuck me i've never seen 1 like that before lol
Physio's Avatar
Physio
oops!
Old Feb 28, 2008 | 08:36 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I posted the same pic in that best engine thread, in reply to you saying the vtec, lol
Old Feb 28, 2008 | 08:37 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Any idea what caused such a major failure?
Old Feb 28, 2008 | 08:40 AM
Chip's Avatar
Chip
Id imagine a rod went, then as the crank pushed it back up it tipped over and jammed into the side of the bore, given how thin the block walls are (and made of ally) it wouldnt be able to take that sort of loading
Alps Pacino
Didnt see it lol, 1 pic of a wrecked vtec motor hardly mens there a wanky engine imo they are a cracking engine but obviously do fail like every other engine can for 1 reason or other
Old Feb 28, 2008 | 08:42 AM
Chip's Avatar
Chip
I agree totally mate, awesome engines, and with regards to this picture, I bet a rod went first, which can happen in any engine, so im sure its not a design flaw of the vtec itself.
Old Feb 28, 2008 | 08:45 AM
vroomtshh's Avatar
vroomtshh
Not according to Honda! They say they have never had a vtec engine fail.
But I suppose it depends what you class as failure, as technically, that engine could be repaired.
Old Feb 28, 2008 | 08:46 AM
Alps Pacino
I'm going to get a s2000 i think to replace the 3 door, there is a lad i know who has just supercharged his s2000 which made 340bhp at the wheels at onlt 6psi which cost him a grand total of 3000 pounds lol. I think i might give him a bell and find out the ins and outs of the conversion and get took for a spin in it
Chip's Avatar
Chip
Honda dont mean including 1000bhp drag motors or whatever this was, they are referring to a standard engine.
Old Feb 28, 2008 | 08:47 AM
Alps Pacino
They say they have never had a vtec fail under warrenty, plus i'm guessing running 1 out of oil and the likes wouldnt be considered as a engine failure
Old Feb 28, 2008 | 08:48 AM
Chip's Avatar
Chip
Bet thats a properly fast car.
Old Feb 28, 2008 | 08:50 AM
Physio's Avatar
Physio
The brother of a friend of mine had an S2000 with a supercharger conversion, apparently it was mental!
Old Feb 28, 2008 | 08:53 AM
Alps Pacino
Its meant to be mental but peoples views of mental seem to vary vastly, the most amazing thing is though that its still on a completly standard motor including head gasket EVERYTHING. A simple bolt on supercharger and exhaust and remap are the only mods apparently
Old Feb 28, 2008 | 09:19 AM
Dan's Avatar
Dan
Proper job!!
Old Feb 29, 2008 | 07:17 AM
Karl 3dr's Avatar
Karl 3dr
Surely thats beyond repair??
Old Feb 29, 2008 | 07:38 AM
vroomtshh's Avatar
vroomtshh
Not really. New block, crank, rods, pistons, pretty much everything in the bottom end and its repaired. It depends what you class as a repair :-p
Old Feb 29, 2008 | 08:16 AM
It's Czech Mate's Avatar
It's Czech Mate
Thats utter bollox because two of my friends have both taken Civic type R's back to the dealer, one with a craked block and the other with a cracked head!
You guys will beleive anything
Old Feb 29, 2008 | 08:18 AM
vroomtshh's Avatar
vroomtshh
And were they both repaired? No1 mentioned that they believed it.
Old Feb 29, 2008 | 08:19 AM
gingeRS's Avatar
gingeRS
neither of those are failed V-tec units though are they
Old Feb 29, 2008 | 11:52 AM
Karl 3dr's Avatar
Karl 3dr
Yeah but if you're changing everything relating to the bottom end, then essentially its not the same engine?
Its a bit like Triggers broom on fools and horses, saying he's had the same one for years even though its had 10 new heads and handles or whatever.
Old Feb 29, 2008 | 12:14 PM
cjwood555's Avatar
cjwood555
the specific wording in honda literature is that they've never had a single failure of a VTEC _SYSTEM_ - take that as you will
Old Feb 29, 2008 | 12:28 PM
Nash's Avatar
Nash
Cake lover!
Depends what caused the Failure though. If it was down to the owner not looking after it or miss treating the car then its not there fault it went tits up.
Old Feb 29, 2008 | 04:41 PM
RickyLee53's Avatar
RickyLee53
Sounds a little optimistic, but i reckon 9psi would see you 340 at the wheels.
I use an S2000 a lot, and there a little tail happy but awesome cars.
I've also got a civic turbo and that was probably about 230 atw on 11psi. (was on standard internals, i'm oin the process of building a new engine for it now)
If you go for it, deffo get hondata ECU, there very good, and also make sure you HPI the car Lot's have been crashed.
Old Feb 29, 2008 | 04:53 PM
RickyLee53's Avatar
RickyLee53
Like i said, my civic was around double it's standard power maybe a little bit more, everything was standard, head gasket included. Plus the engine had done 144k miles
I don't believe you... but anyway, sounds like your mates need to start using anti freeze.
Old Feb 29, 2008 | 05:33 PM
It's Czech Mate
Want the registrations and the name of the two dealers?
Both cars had replacement engines and both were less than two years old, neither owner was told they had mistreated the car and both had been serviced properly at the respective dealers , so believe what you like, I know what I know
Old Feb 29, 2008 | 05:48 PM
Alps Pacino
who cares i like the b series better anyway lol
Old Feb 29, 2008 | 05:50 PM
It's Czech Mate
everyone who misguidedly says honda has never had a vtec engine failure care, its got to be one of the most misquoted things on the internet!
Old Feb 29, 2008 | 05:54 PM
Alps Pacino
jeremy clarkson said it on top gear also so its not jut the net
Old Feb 29, 2008 | 06:05 PM
vroomtshh's Avatar
vroomtshh
Its nothing to do with the net. Its a claim that Honda make in their own literature. And, personally, I feel its a claim they can back up. Or else they would have had the shit sued out of them already
Old Feb 29, 2008 | 06:54 PM
Escy's Avatar
Escy
I'm pretty sure their claim refers to the mechanism they use to switch to the VTEC. Thats the bit that's never failed. I think it's a pushrod that locks something or other, can't quite remember.
Old Feb 29, 2008 | 06:57 PM
Alps Pacino
it works on oil pressure basically it locks the middle rocker onto the NORMAL 2 so the 1 vtec rocker in affect push's the 2 valves ie 6 lobes per cylinder 4 normal 2 vtec
Old Feb 29, 2008 | 07:08 PM
RickyLee53's Avatar
RickyLee53
Please,
I know a few people with type R's and no1 had such problems. Also i've got an article of 1 that did 21k revs. Was FOOKED but still ran.
Just looked again at that block, its a B16, with sleaves in it, and H beam rods, it's clearly been turbo'd and no doubt was BIG power.
Old Feb 29, 2008 | 08:11 PM
It's Czech Mate
Again you're misquoting it. It says they've never had a vtec unit fail, which isnt a vtec engine
Its like saying ford fiestas are uber relaible because they've never had a bonnet stay fail
I'm not denying they are great engines and they are very relaible, but i know of more than two failures and several with mystery oil drinking problems that the dealers refuse to touch.
The mis interpretation of the quote is awesomely annoying tho.
Old Feb 29, 2008 | 08:34 PM
Alps Pacino
ALL vtec engines use oil its just part and parcel of that engine, like cossie and there cracked blocks lol
Shows & Track Days
Apr 27, 2016 11:04 AM
tankybaby66
Feb 6, 2016 02:24 PM
Sep 28, 2015 10:05 AM
cameron2
Sep 6, 2015 10:42 AM
