6 pots refurbed
6 pots refurbed
I have a set of wilwood 6 pots that could do with repainting could anyone recomend anywhere in the north east who could do a good job.
I would try myself but would make an arse of repainting the letters on them.
N
N
Don't know yet I have just taken them in partex against a set of 336mm tarox 6 pots that didn't quite fit under my 17's.
I'm going to get the rotors skimmed, fit new seals to the pistons , fit new pads and hopefully get them painted bright red with white lettering instead of silver and red.
I hope after that they should work much better than the standard size ebc's I removed.
Thanks for the tips Beefy, Rob.
I dropped them off this afternoon with Jacko and karl, sound lads there going to blast and paint the calipers and get the discs skimmed for me.
Seal kit is a very reasonable £17 from rally Design
N
N
now mate callipers just need the lettering doing and the seals seem to be fine i took the pistons out and cleaned em disks dont need a skim just a good clean up will be finnished wednesday
Full set of 40mm lowered springs mint plus 2 brand new front ones also front koni adjustables only done a couple of thousand miles 1 has a snapped adjuster on the top I'm sure it can be repaired easy enough but cause I wanted mine mint I bought 2 new ones I got a deal on.
Minirotty
11
15-09-2015 10:16 PM
