zetec turbo best c/r
Old Feb 24, 2008 | 02:42 PM
NEWTON's Avatar
NEWTON
Default zetec turbo best c/r
which comp ratio would be best to run big boost thanks
Old Feb 24, 2008 | 03:00 PM
crazycage's Avatar
crazycage
about 9.1
Old Feb 24, 2008 | 03:07 PM
Andy_R's Avatar
Andy_R
or 7.1
Old Feb 24, 2008 | 04:02 PM
JamboRS's Avatar
JamboRS
focus rs 1672
cant say,engine needs to be specced for what it requires,too much other things to consider,turbo,head,inlet exhaust all needs to be considered
Old Feb 24, 2008 | 04:20 PM
crazycage's Avatar
crazycage
Originally Posted by Andy_R
or 7.1
is yours 7.1 then mate ?? my new build is 8.8.1 ,what sort of power you going for? i want 330-360 .
Old Feb 24, 2008 | 08:15 PM
juffer's Avatar
juffer
i'd say 7.4:1 thats what my engin builder said
Old Feb 24, 2008 | 08:27 PM
AustenW's Avatar
AustenW
Old Feb 24, 2008 | 09:16 PM
NEWTON's Avatar
NEWTON
Originally Posted by crazycage
about 9.1
ive got rods and pistons from the states,that give 9-1 ratio with a 48cc zetec head,thought that might be a little high? i was thinking more the lower 8,,,,8-2:1example
Old Feb 24, 2008 | 09:42 PM
rstdave's Avatar
rstdave
Another open ended argument that's bin done a few times on here.....different people seem to use various c/r's and get good results.....i'd take the advice of your tuner and who's gonna map the car....if they've got proven results go with what they suggest imo! Personally i'd go for nothin below 8:1....but that's just my opinion and that of the tuner i take advice from.
Old Feb 24, 2008 | 10:07 PM
JamboRS's Avatar
JamboRS
focus rs 1672
andys will be a tame 300@wheels,though i dont reckon it will stay there for long,power bug will kick in,dunno what the engines specced for,though i think its well higher than the 300 that andys will settle for
Old Feb 24, 2008 | 10:28 PM
NEWTON's Avatar
NEWTON
Smile
thats good advice ,nothing below 8-1,i dont want the car to drive like a pig off boost,ill be using the car a a fast road car and for a few track days
Old Feb 26, 2008 | 12:24 PM
sas's Avatar
sas
should be good!
I am running 9.1 to 1 in my Zetec turbo.
S.
Old Feb 26, 2008 | 11:30 PM
NEWTON's Avatar
NEWTON
S.
why so high? what boost do you run on that comp? thanks
Old Feb 26, 2008 | 11:49 PM
smitsturbo's Avatar
smitsturbo
7.3;1 is what mine will have...im told
Old Feb 27, 2008 | 07:27 AM
sas's Avatar
sas
should be good!
I am maybe getting carried away as I only have got upto 21psi and the thing is the fastest car I have ever driven. You have to run V-power fuel.
Last year my Zetec Turbo was 8.5:1 and in combination with its big turbo had a fair bit of lag, but now at 9.1:1 I have no lag and the car is very nice to drive.
Simon.
Old Feb 27, 2008 | 01:23 PM
NEWTON's Avatar
NEWTON
Simon.
thanks sas,is your engine an st170 zetec?iam thinkin of a six speed box allso,you have any prices on the shafts and mounts to be made up?thanks again
Old Feb 28, 2008 | 11:12 AM
Maki's Avatar
Maki
The question would be what sort of a car you want to have?
Drivable car should have no les than 8.7:1 but if you want mad boost with big turbo, go as low as you can... the lower the CR the higher the boosts safe limit. You'll have the lag, but you'll have power that you will not handle when the turbo kickes in By the way with to low CR it is hard to start the engine. Thats' my opinion... 8.2:1 for me always as I like the power kick whick you don't feel so much with high CR cars and low boost. That's what they do to NA hondas ... high CR, low boost... 250 BHP and it pools all the time, but not as fun as our fords with that boost kick
Old Feb 28, 2008 | 12:28 PM
NEWTON's Avatar
NEWTON
thanks mate,i like to feel the boost kick in hard more fun like that
Old Feb 28, 2008 | 01:30 PM
Andy_R's Avatar
Andy_R
I dont know where the misconception that low compression = lag comes from, its simply not the case at all. An engine built and spec'd correctly matched with a decent turbo and with propper mapping, will not result in a laggy drive.
I've driven more than just a few Turbocharged cars where the complression ratio's are well into the low 7's (and below) which were all far from laggy.
Old Feb 28, 2008 | 01:48 PM
Maki's Avatar
Maki
Good example is 1.6 CVH xr3i and 1.6 RS Turbo... Of the boost NA 1.6 is more responsive and thats got to do mostly with the CR
P.S. people should start knowing, that thing which we like to call "lag" should be called "spool up time".... in real theory "lag" is the time between shifts and not the time before turbo kicks in from the start that is called "spool up time"
Old Feb 28, 2008 | 02:02 PM
Andy_R's Avatar
Andy_R
Im sure if modern day engine managment were added to the RS Turbo then the outcome would be somewhat different.
Old Feb 28, 2008 | 02:11 PM
Maki's Avatar
Maki
The same thing's could be done to those NA 1.6 engines, so... it's just the comparition
Old Mar 1, 2008 | 12:42 AM
NEWTON's Avatar
NEWTON
thaks everyone
Old Mar 1, 2008 | 05:37 AM
JesseT's Avatar
JesseT
Also, I can't think where the misconception of "big turbo need low CR" comes from as it's just the opposite. It's the restrictive exhaust housing that creates much of the detonation problems for high CR engines.
There are loads of turboed 16V engines running CR from 9-10 with 2bar boost and silly power with turbos like Holset HX50 fitted.
Old Mar 1, 2008 | 07:58 AM
Maki's Avatar
Maki
I know none maybe WRC focus, but we don't have that king of money I guess... I street life there is simple rule. low CR - high boost, high CR - low boost.... and for high CR/low boos't car you don't need huge turbo, but I dont know why are they using them, maybe for show off "look at me I have BIG turbo" or maybe for that reoson you've mentioned, restrictive housings... I can't say. In my region all the big boost and power cars have so low CR's that for starting they need additional injectors and so on...
Old Mar 1, 2008 | 06:13 PM
rstdave's Avatar
rstdave
Think there's more cars runnin big power/high comp than u think.....there are some jap cars, evo's definately that i know of running c/r in the 9's and over 700bhp so it's possible. Low comp is tried and tested obviously but more people are managing to get the power with higher c/r's now. As for high comp and big turbo's...that's the whole point, means you can get power without havin to run mega boost, don't know what the obseesion with massive boost is, if u can get the power running lower boost it's gotta be better...lower temps and strain on everythin etc. The low comp versus high comp is always goin to be argued either way but high comp/ big power can definately work if specced correctly!
Old Mar 1, 2008 | 06:43 PM
Maki's Avatar
Maki
...if u can get the power running lower boost it's gotta be better...lower temps and strain on everythin etc. The low comp versus high comp is always goin to be argued either way but high comp/ big power can definately work if specced correctly!
We talked about it ... simply no fun with no boost kick fuck jap crap
Old Mar 1, 2008 | 06:50 PM
Red16's Avatar
Red16
lag is the time it takes to make positive boost pressure... whereas boost threshold is the time it takes to get from just masking positive boost pressure to actually making full boost.
Old Mar 1, 2008 | 06:56 PM
Maki's Avatar
Maki
We read different books
Old Mar 1, 2008 | 06:57 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I haven't cc'd mine yet but theoretically mine should be low to mid 8's and i'm aiming for 450-500bhp
Old Mar 1, 2008 | 11:21 PM
JamboRS's Avatar
JamboRS
focus rs 1672
i thought lag was the time from positive boost pressure to full boost,boost threshold is the time it takes for the turbo to spin up,as in off boost comin onto positive boost
no?
Old Mar 2, 2008 | 06:05 PM
wul young's Avatar
wul young
totally agree andy,mines is 7.5.1,spect to run 28psi,and 1 thing is for sure,my car has no lag whatsoever,thats with t34,andy and several other people who have been in my car will verify this,as said proper management, mapping,ignition advance etc play a vital roll between lagy and not.
Old Mar 2, 2008 | 08:52 PM
rstdave's Avatar
rstdave
Guess it depends what u want out of your car......if fun's havin a car that's laggy as a peach off boost then lightin em up everywhere when it finally makes boost then fair enough! If it's a quick point to point car then linear power's what you want really....as for jap crap, agree it's not what i'm into either but there's no arguing their methods make for some fuckin quick motors!!
Old Mar 2, 2008 | 09:55 PM
Maki's Avatar
Maki
Then you should stay NA... plenty of cars with big power enough to spin wheels on dry, so why going turbo way at all in FWD car?
Old Mar 3, 2008 | 09:58 PM
rstdave's Avatar
rstdave
Should i now lol......what because i don't want some lag monster with a massive boost spike that just lights up the tyres??!! Don't know what the fascination with spinning the wheels is...plenty of big power turbo fwd cars that put in some very impressive times without doing so....and funnily enough they're the ones that manage to avoid having massive boost/torque spikes!! I've got an rst so obviously have nothin against turbo and fwd...think you're totally missing the point....that they can be made to go quickly without just lightin up the tyres!
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
