4X4 COSSY
Old Feb 23, 2008 | 05:44 PM
TAYLOR4X4's Avatar
TAYLOR4X4
Default 4X4 COSSY
CAN SOME 1 TELL ME THE SEQUNCE FOR THE LEADS FOR THE DISTRIBUTOR CAP TO THE CHAMBERS
Old Feb 24, 2008 | 04:57 PM
The quickest way to tell is take off the dizzy cap, put car in gear(5th) and pull towards you till the timing marks are aligned, ie the LUG next to the "V" groove, now your rotor arm will be pointing roughly at the nearside wheel, if not just pull a bit more, noting which way the dizzy moves(CLOCKWISE), till marks are lined up once more.
Now look at caps position when installed, and you will find the arm pointing at NUMBER 1 CYLINDER, the front one, the next is 2 etc the rear one is four.
The firing order is 1,3,4,2( as nearly all 4 cylinders), then just work the next lead "3" CLOCKWISE in the dizzy cap, and connect to number 3 plug, then number 4 position to number 4 plug, finishing with number 2, the centre is the coil lead connection.
This is for a STRAIGHT cap, if angled the numbers are from left to right, when standing at front of car looking at engine(so offside to nearside looking), cylinder 4/2, next terminal is lower in the centre and is the king lead from the coil, then 1/3
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
