cossie using loads of fuel
Old Feb 23, 2008 | 04:48 PM
155lee's Avatar
155lee
Default cossie using loads of fuel
firstly ill say im NOT complaining about the mpg or anything like that,but i genuinely believe that my car is using a lot of fuel.it has been sitting around for about 2 years and has only covered 600 miles in that time.it idles a bit high and the revs sometimes dip and rise when it is ticking over.there are no leaks and i am not using it hard.is there a sensor or injector that can fail causing it to burn more fuel?the tailpipe is no more black than normal but it does smell a bit rich!any ideas?
Old Feb 23, 2008 | 04:55 PM
mechanic28's Avatar
mechanic28
your iscv probably needs a clean out
Old Feb 23, 2008 | 04:57 PM
155lee's Avatar
155lee
does that cause a fuel problem like im having?i know it makes the revs rise and fall if its choked up!
Old Feb 23, 2008 | 05:39 PM
TurboShed's Avatar
TurboShed
Cossiemodo
For the last couple of weeks I've noticed my Cossie is using loads of fuel, I'm getting 200 to a tank around town. I put it down to the cold, and I normally warm the car up before setting off, which takes a while in this cold weather.
Old Feb 23, 2008 | 07:34 PM
xr_craig's Avatar
xr_craig
When was it last set up mate? Mine was pretty similar to be honest, it was costing shitloads to run and the emissions were sky high. Worth getting it looked at in my opinion as it could save you costly repairs in the future
Old Feb 23, 2008 | 08:17 PM
155lee's Avatar
155lee
never i bet.it was totally standard and had been owned by the same guy for 9 years.i doubt he ever had it set up,the guy after him only had it a short while and the thieving scumbag that nicked it probably never set it up either.thats why it has sat for so long,1 year in a salvage yard then 1 year with me being rebuilt and made better.im going for a stage 3 conv soon so ill put up with its thirst till then.unless its an easy fix as my nearest reputable tuner is miles away!
Old Feb 24, 2008 | 10:59 AM
chavez's Avatar
chavez
Default iscv ?
What is the iscv where is it and how do i clean it oit buddy ?
Old Feb 24, 2008 | 04:30 PM
The ISCV will NOT affect the mpg, but does control the idle speed, it is located on top of the throttle housing, and has a two pin connector plug going to it.
Clean by spraying with carb cleaner liberally, then spray with silicone spray or silicone polish afterwards.
Most likely is the injectors have gummed up, very common with low use cars that sit for ages.
If going stage three you will have to change the std yellows/blues for either greens, normally reffered to as 803's, or siemens injectors depending on the chip etc that you use, so again I wouldn't worry till then, though injector cleaner will probably help a LITTLE, and is cheap in the meantime.
Old Feb 24, 2008 | 04:33 PM
155lee's Avatar
155lee
ill maybe give it a go just to see if it does what it claims,always been curious to see if it works!
Old Feb 24, 2008 | 06:34 PM
cozzycol's Avatar
cozzycol
i had a similar problem with mine
using loads of fuel and the revs went up and down a bit
turned out to be a very slight leak on the inlet manifold gasket
col
Old Feb 24, 2008 | 07:00 PM
The only 100% effective way to clean injectors, is with a ASNU or similar ultrasonic cleaner, this is what I always do mine with, if you have to pay to get it done about £50/60 normally for a set.
Old Feb 24, 2008 | 08:14 PM
155lee's Avatar
155lee
the revs dont go up and down all the time,i spoke to my friend,he has a stage 1 2wd cossie,i told him how much fuel i was using and he said he would get a lot more mpg to me,i dont drive mine hard and neither does he,he reckoned he would get about 75 miles to £10 of fuel,i dont think i would get that.how do you check for a leak at the inlet manifold?
Old Feb 24, 2008 | 08:20 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
try changing your coolant sensor, did this one mine before it died and the mpg went up to about 30 on a run.
Old Feb 24, 2008 | 09:15 PM
STUCOS's Avatar
STUCOS
get it set up,and converted to closed loop
cheeRS stu
155lee's Avatar
155lee
cheers,think my pal might have a spare good 1,he changed them all when he was having bother with his,still didnt cure the misfire.i also noticed the fans are not coming on,is that the same sensor or is it the switch that screws into the rad?
Old Feb 24, 2008 | 09:17 PM
155lee's Avatar
155lee
stucos,who do you recommend around here?
Old Feb 24, 2008 | 09:32 PM
STUCOS's Avatar
STUCOS
Nobody mate,thats why i do 90% my self and www.sitechracing.co.uk do the rest
cheeRS stu
Old Feb 25, 2008 | 06:26 AM
Fans are controlled by a fan switch and VERY dodgy ford wiring.
A rewire is a MUST DO THING.
CTS sensor only gives info to ECU, fan control totally seperate, most end up burning out the fusebox terminals sometimes with fires etc!!
75 miles on a tenner is pushing it a bit unless he is extrememly gentle, my stage one used to do on a run 34, but was GGR chip, but buggered if I can drive that sensibly for long, didn't get the car to do that!!
Old Feb 25, 2008 | 07:33 AM
TurboShed's Avatar
TurboShed
Cossiemodo
I'm getting about 75 miles to £20, and that's not thrashing it. Ok stage 3 Greens etc, but still, doesn't seem right.
Old Feb 25, 2008 | 08:08 AM
KSA-Cossie's Avatar
KSA-Cossie
Talking
cheeRS stu
Spot on.
Old Feb 25, 2008 | 03:04 PM
Get an Emerald, I just bought one, though have to wait for new stock, as "selling like hot cakes", can't wait!!
Old Feb 25, 2008 | 05:53 PM
Whats an emerald tabetha?
Old Feb 25, 2008 | 06:05 PM
Emerald is a make of ecu, 3d aftermarket one, lives about 1/4 mile from me so really usefull.
Old Feb 25, 2008 | 06:15 PM
155lee's Avatar
155lee
just bought a new blue temp sensor and a new fan switch off ebay,£10 each.bargain!ill fit them when i receive the rest of my service parts and post up if theres any difference!
Bailes1992
Sep 3, 2015 02:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
RsS2daz
Aug 14, 2015 05:26 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
