zetec running rough!!??
Old Feb 19, 2008 | 10:55 PM
ShandzS1's Avatar
ShandzS1
Default zetec running rough!!??
I had an oil pressure prob with my 1.8 zetec 130 thats in a mk3 esc. so removed sump+exhaust etc and oil pressure regulator, put it back together and wound it over, sorted gauge went up no probs. but when it started its like its flooding all the time, and plugs and tops of pistons look wet with petrol. Poss faulty lambda? sending wrong signal to ecu??
Old Feb 20, 2008 | 02:21 PM
track scort's Avatar
track scort
Maybe lambda sensor could have been disturbed when removing exhaust etc. When you turn the ignition on is everything priming like normal, fuel pump etc?
Old Feb 20, 2008 | 02:29 PM
sexr3i's Avatar
sexr3i
isn't it
Probably lambda yeah. Check the fuse first, it's in that little box I put together.
Old Feb 20, 2008 | 08:11 PM
ShandzS1's Avatar
ShandzS1
Ive tried disconnecting the lambda and no change, yeah al check it the now, karl did u get my msg about my st170 loom?
Old Feb 21, 2008 | 05:17 PM
sexr3i's Avatar
sexr3i
isn't it
yeah man i replied to ya.
Old Feb 22, 2008 | 09:17 PM
Rsailor's Avatar
Rsailor
Did you remove the inlet manifold?
Check your pipe work for leaks.
Old Feb 24, 2008 | 04:22 PM
ShandzS1's Avatar
ShandzS1
Its defo the lambda probe, cheers for the help!!
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
gingerturbo
Aug 18, 2015 07:58 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
turbobill
Aug 9, 2015 05:21 PM
