xr2 wont start
Old Feb 18, 2008 | 08:48 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default xr2 wont start
hi all
ive got a 1988 mk2 xr2 running twin 40 carbs.
when i tryed to have it set up i was told the the valves were not sealing propley and to change the cam for a cvh 22.
ive since taken the head off, done the valves and cam put it all back together. now it wont start but turns over really slowly ive got a spark and fuel timing marks all line up but it wont go
any pointers to get this going would be great
many thanks dave
Old Feb 19, 2008 | 05:59 AM
Re check cam timing, check ignition timing is at the right point, check plug leads correct order.
If it is a new engine, sometimes there is not a very good seal between pistons/bores, so a little oil in the bores helps the seal and gets it going, a trick often used on older cars that have been stored for years.tabetha
Rob Wells
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
