FRS HELP NEEDED!!!
Old Feb 15, 2008 | 03:53 PM
pauldonachyrs's Avatar
pauldonachyrs
Default FRS HELP NEEDED!!!
Can Anyone Tell Me Wot The % Is Standard On The Turbo Wastegate On The Race Plus Map On Dreamscience Cause I Have Been Messing About Wee It And Cant Remember Wot It Was Set At ....
Old Feb 17, 2008 | 01:14 PM
DAZ1RSNUTS's Avatar
DAZ1RSNUTS
i think its about 60%, i also think,cant remeber with out plugging mine in!!
if you load in a different map then load race+ map again it will go back to normal race+ setting,if this is no help ring dreamscience in hull they will tell you
Old Feb 18, 2008 | 04:44 PM
pauldonachyrs
i check mate 70% is the lowest it goes on race plus so take it thtss the std settings
JoeyBoyden
Jan 4, 2024 02:36 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
borboyous
Aug 22, 2015 11:17 AM
Churtz
15
Aug 13, 2015 06:40 PM
col93saphcos
Aug 7, 2015 03:21 PM
