FAO MOT experts
Old Feb 15, 2008 | 12:35 PM
Rob84's Avatar
Rob84
Default FAO MOT experts
Will a car fail if its front ARB is disconnected one side? i.e. no drop link....
Thanks in advance
Old Feb 15, 2008 | 12:41 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
yes
Old Feb 15, 2008 | 12:43 PM
Rob84's Avatar
Rob84
Originally Posted by Matt Baxter
yes
ok so would it still fail if both sides were disconnected?
Old Feb 15, 2008 | 12:45 PM
Matt Baxter
Back in black!
yeah mate it will deffo fail on a part(s) missing
Old Feb 15, 2008 | 12:46 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
remove the whole ARB and its fine tho
Rob84's Avatar
Rob84
ah fuck... best wait till I get my drop link bracket repaired before MOT'ing. Thanks buddy
Old Feb 15, 2008 | 12:52 PM
Matt Baxter
Back in black!
it would still fail as a vehicle known to be fitted with an arb as standard and had it removed is a reason for rejection
Old Feb 15, 2008 | 12:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
only if the MOT tester was being a cunt, as almost all modified cars have something removed that was there as standard that would fail if only 1 of em was missing...
Old Feb 15, 2008 | 12:55 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
my mates past with no ARBs on a mk4 escort probably he didnt know much about mk4 escorts so he did not know
Old Feb 15, 2008 | 12:56 PM
C4llyT's Avatar
C4llyT
Indeed, gotta be there if standard fit.
C4llyT's Avatar
C4llyT
ARB's are specifically mentioned in testers manual.
Not being a cunt, doing his job properly more like.
Old Feb 15, 2008 | 12:57 PM
Matt Baxter
Back in black!
only doing his job though
Old Feb 15, 2008 | 01:03 PM
It's Czech Mate's Avatar
It's Czech Mate
Well they cant fail you for no spare wheel or no seats if you take them out so I fail to see why you'd get failed on an ARB that was taken off
Old Feb 15, 2008 | 01:05 PM
Matt Baxter
Back in black!
HTH
http://www.motuk.co.uk/manual_240.htm
Old Feb 15, 2008 | 01:08 PM
fraser9764's Avatar
fraser9764
i put a subaru justy through with no anti roll bar the other week because the bushes were knakered.
no questions asked, but then again, how many people know about subaru justys, most people dont know they exist let alone wether they have an anti roll bar
what car is it on?
Old Feb 15, 2008 | 01:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's got a spare wheel it's got to be legal
but that's not a safety issue, removing your arb will leave big bolts and holes where it would normally live so it's not the most obvious thing you can hide away is it
Old Feb 15, 2008 | 01:13 PM
Matt Baxter
Back in black!
not for the mot the old bill can do you for it tho
Old Feb 15, 2008 | 01:21 PM
C4llyT's Avatar
C4llyT
WTF
Testers don't make the rules up, follow their manual
If you've a problem, take it up with the ministry, don't come out with shit here and make yourself look stupid
Old Feb 15, 2008 | 01:22 PM
C4llyT's Avatar
C4llyT
No it hasn't
Old Feb 15, 2008 | 02:39 PM
dojj's Avatar
dojj
why not then?
Old Feb 15, 2008 | 02:57 PM
C4llyT's Avatar
C4llyT
Dunno, do I work for the ministry?
MOT's are just a joke really, ministry man picked me up for failing track rod ends for play in them.
Said they had to be hanging apart before a fail, not just a bit of play.
Same for bad rust in sills etc out of prescribed areas, mate was picked up on that. Said only seen that applied correctly once, and that was when he stood on sill the car bent under his weight.
Old Feb 15, 2008 | 03:20 PM
dojj's Avatar
dojj
there's always the argument that you can pass an mot and yet the old bill can nick you as soon as you drive out
Old Feb 15, 2008 | 03:21 PM
It's Czech Mate
WTF
Nothing i have said is wrong :s apart from the fact the ARB is explicitly mentioned in the manual which i didnt know!!!!!
My point about the spare wheel and seats still stands correct.
You can pass woth no spare wheel yet fail with a bald spare
I once removed the rear seats from a car to pass the MOT as the rear seatbelt inertia reel was fooked, so before I took it to test station off came the seat and the bits the belt clips into and hey ho a pass. You arent obliged to test something that isnt there unless explicitly stated in the manual. ( like ARB's )
Old Feb 15, 2008 | 03:23 PM
C4llyT's Avatar
C4llyT
I should hope spare wheel point stands, as Rover sold cars with no spare, just a can of tyre weld
Old Feb 15, 2008 | 04:12 PM
NEO™®©'s Avatar
NEO™®©
nope cos it can still fail if its meant to have had one fitted
Old Feb 15, 2008 | 04:15 PM
pee vee's Avatar
pee vee
and new ST focus too.. not that rover sold them,,,, they might not be out of business if they did
Old Feb 15, 2008 | 05:11 PM
Twellsie's Avatar
Twellsie
so what if you have removed the ARB to run compression struts, would it still fail?
Old Feb 15, 2008 | 05:17 PM
C4llyT's Avatar
C4llyT
If one was originally fitted to that axle, it needs to be there.
Old Feb 15, 2008 | 05:38 PM
Moose 130's Avatar
Moose 130
and a spare wheel only becomes illegal when you fit it, so for the MOT it's not a requirement.
it might be advised if the tester wants to.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
