nitrous on a s2 erst ????
Hi,
I am seriousley considering getting nitrous on my car, mainly to help with the lag from the turbo & cam but also to give it that extra kick
Just wondered if anyone else has it fitted, what make of kit is it and most importantly does it work well ? I was thinking of 50bhp jets as apparently you dont notice 25 and I think 100 is pushing it a bit !!
Also, can you get different types of kit ie. wet, dry etc
does anyone know what this all means and which kit should be fitted to the erst engine ? its still a 1.6cvh by the way.
cheers, Duncan
cheers, Duncan
I had Nitrous on my S2, heres a pic. I can answer some questions so ask away.
What power jets were you using and was it noticable ?
Did you get any problems with the engine ?
How long did it take to install and was it easy ?
cheers mate
, Duncan
wouldnt put nos anywhere near a turbo'd CVH!
220TC
Wet kit which basically means it puts fuel in with it, Dry doesn't. It's a NOS kit.
50 jets, yes very noticeable made 84 bhp.
No problems ever, so long as correctly setup.
Took a day to install and isn't that complicated.
cheers mate, once I've saved some money I'll probably invest in some ! hopefully I'll crack the 300bhp mark
was it easy to set up, what was involved etc....
also, whats that thing fitted on your crossover pipe just above the bolts, on the right
Duncan
Duncan
Mc5506
Oct 5, 2015 09:57 PM
