frst - zetec inlet manifold adaptor plate
so that you can use the frst efi inlet manifold on the zetec engine.
ideal if you plan to use ofab management on a zetec turbo as can use uprated frst injectors.
also has a spacer to raise the inlet as the zetec rocker cover is higher.
£40 in north east london
JK12
33
Apr 26, 2021 12:09 PM
