Zetec Turbo
Old Feb 10, 2008 | 09:32 PM
mikeyrsturbo123's Avatar
mikeyrsturbo123
Default Zetec Turbo
Hi i have a Mk6 Escort 1.8 Zetec which im thinking about putting an Escort Turbo manifold and unit onto it and all other relevant parts.
What Ecu is recommended? Also any other advice into doing the conversion would be great
Thanks
Old Feb 10, 2008 | 10:40 PM
NATH-RSZT's Avatar
NATH-RSZT
if you dont know what your doing and have some spare cash click link below my sig
Old Feb 11, 2008 | 06:36 PM
Phil2002's Avatar
Phil2002
Take a look at this site it has a guide to turbo a zetec www.smartefi.com also try www.fiestaturbo.com. www.zetec-turbo.com.
with these guides you should be able to sorce the bits your self and get a machine shop to to the hard work and save your self a packet rather than letting some one do the hole thing for you. search ebay.com for zetec stuff pistons and h section rods are cheap as fuc* at the mo as the dollar is so weak against the pound my zetec turbo pistons cost me £200 and that included delivery from the usa. i also got a t4 turbo made in the usa (not a cheap jap hunk of shite) with 360 thrust bearing for £160 brand new.
the main things you need to do are change the pistons for forged ones standard pistons and a de comp plate waste of money and effort the pistons are too weak. if you dont want to make more than 250 bhp standard rods are fine but would recommend arp big end bolts. the breather needs blocking up at the front of the block and relocating to back. and a oil return needs to be put in the sump or the block for the turbo oil feed for turbo can be taken from the oil pressure light switch with a t piece. Loads of info on the net and this site have look about if you need any more help just ask
Phil.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
