2.3 / 2.4 Stroked YB's
Well worth doing but the problem is getting the longer stroke crank in with decent length rods as obviously the longer the stroke then the shorter the rod needs to be. But there are ways around having to run really short rods the easiest being changing the pistons for ones with the pin sited further towards the top of the piston or make the block taller.
The end result is that you can run a big turbo and still have the low down drivability of a small one.
I reckon 2.2 is about the max with a std height block if you still want it to feel nice when using high revs.
I don't know why more customers don't go down this route.
Funnily enough I was just in the garage looking for an old car mag and was reading the "Top Car" article on the old Power Engineering RS2400s. If people are interested I could scan it in tomorrow?
Originally Posted by beefy-rst-2
could be somthing to do with the price ?
stroking a motor cant be cheap ??
i mean crank rods pistons ??
just a shame for the ford boys nobody mass produces a cossie stroker crank
Originally Posted by c20tbo
This customer is Mr Reyland.
I Know Mark thinks 2.15 is optimum with a standard Block height & his stroker has slightly changed rods & a pin moved up the piston. The exact dimension are selected to get the optimum angles, please dont ask what that is because I dont understand it. However it means bespoked Crank, Rods & pistons. Although not cheap its the preparation of the Block to withstand the Big Horsepwer that can be achieved with this combo that costs the money.
Guest
Posts: n/a
Originally Posted by NEEDFORSPEED
some going that yum! what sort of differences do you see from the mis inlet?
We didnt get to find out. Rod was going to do a test his against mine but the dyno day finish early.
Might get to try the test again when rod goes to the dyno
And it might even be a TUV dyno so we cant correct or make up the figures
Id like to try a long stroke and a shorter rod to achieve the capacity, on a road only motor, but the opposite of martins, in that it would be designed NOT to rev, just to achieve a moderate power level (like 400-450bhp) at say 5000rpm but with monster torque for that power and much better torque than normal at very low rpm.
The very high piston speeds around TDC caused by that rod ratio should in theory allow a lot of timing to be dialled in even with fairly high compression as well.
Expensive thing to try "just to see" though obviously as it might end up being shit of course, you dont know with these things till you try, and so far everyone ive seen doing them seems to be doing it for huge power, not just for a moderate power level but very driveable.
Originally Posted by graham c
i looked into this and it woz 1500 quid just for the crank,rods but i woz told they dont rev as quick ?
Potenitally thats a good thing at low rpm, but its a very very bad thing at high rpm, so it depends what you are building the engine for.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
