Remote ISCV
Old Feb 6, 2008 | 02:52 PM
NEIL A's Avatar
NEIL A
Default Remote ISCV
What car/cars ran a cosworth style iscv in a remote housing ? Think i mind some one saying a Lancia and mibi some of the early RS1800?
Old Feb 6, 2008 | 03:03 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Lancia Delta Integrale and this uses the exact same ISCV as well. Check out Fleabay for one, as they are no longer serviced.
Old Feb 6, 2008 | 03:08 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
rare as fook now
last one i bid on went for Ł60 for the remote housing alone
fook that, ill use a pair of vauxhall ones for that lol
Old Feb 6, 2008 | 03:40 PM
WD Pro's Avatar
WD Pro
Still looking for one myself
Old Feb 6, 2008 | 04:24 PM
cossiestu's Avatar
cossiestu
Fiat Tipo 16v iirc?
...Not exactly common either, but you never know!
Old Feb 6, 2008 | 04:30 PM
Rippers's Avatar
Rippers
Monte Geek
You can pic up Lancia Integrale ones for peanuts complete with the ISCV which is the same as the cossie aswell. I paid Ł15 for my last one.
Lancia owners know them as 'slow idle valves' I emailed every breaker on ebay and got offer 3/4 from Ł15-30
They even come with a side mount
Old Feb 6, 2008 | 04:50 PM
NEIL A's Avatar
NEIL A
Mr Ripley does it again thanks Paul
Old Feb 6, 2008 | 05:31 PM
SassyRS's Avatar
SassyRS
Little Miss...
early fiesta/escort efi had a similar iscv, it sat in a housing on the airbox, the valve looked the same as the cosworth one apart from it was red instead of grey.
Old Feb 6, 2008 | 06:12 PM
col cos1's Avatar
col cos1
think i might be needing one of these aswell neil
was speaking to alan other day about the sweedish inlets and he said yours had idleing issues compared to euans on the autronics
Old Feb 6, 2008 | 06:20 PM
jacko996's Avatar
jacko996
can you still run anti lag with the Lancia one??
Old Feb 6, 2008 | 06:24 PM
richm's Avatar
richm
Old Feb 6, 2008 | 06:25 PM
NEIL A's Avatar
NEIL A
Yes Col it is idleing just now but will be a lot smoother once i get a valve refitted. Once the engine has warmed up it is better, but in this weather and with the big rad and no boost it takes a while to heat up.
Old Feb 6, 2008 | 06:36 PM
rapidcossie's Avatar
rapidcossie
My car is pretty much spot on at idle considering it doesnt have a Idle valve.
Even in minus conditons it starts after about 3 seconds of cranking with the throttle half open, to or three blips on the throttle and it settles not to bad.
Alan did say that the autronic has a few pretty useful tables to help with the idle tho and he has spent alot of time on improving it.
Old Feb 6, 2008 | 07:13 PM
glancy2081's Avatar
glancy2081
what about a bosch one off a vauxhall,i will even have one lying around if you want to try it
Old Feb 6, 2008 | 08:40 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
glancy2081
for propper als i was gonna use 2 of them ones.
the plunger doesnt move that much on em, so need 2
Old Feb 6, 2008 | 09:08 PM
markk's Avatar
markk
Originally Posted by Dan@FastFord
glancy2081
the std bosch iscv as found on the crockshals will flow enough to bypass your throttle and raise the idle speed to 4000rpm without retard.
i used to use a modded weber iscv and 1 bosch rotary and without any retard the car would hit the limiter when initiated.
Old Feb 6, 2008 | 10:35 PM
NEIL A's Avatar
NEIL A
I have emailed a few breakers as the integrale one would be the easyest to fit , but had thought about the vaux one but didnt know if it flowed enough or too much air.
Old Feb 10, 2008 | 02:39 PM
NEIL A's Avatar
NEIL A
Still no luck tracking one down , dont supose any one on here has one stashed they want to sell or knows of any forsale.
Old Feb 11, 2008 | 10:31 AM
NEIL A's Avatar
NEIL A
Just phoned Alpha prformance from the above post neither valves in stock and need a minimum order of 100 to get them in
Old Feb 11, 2008 | 10:43 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The vauxhall ones flow a lot more than the cossie ones and are remote mount anyway.
Here's the one on my nova:
Old Feb 11, 2008 | 03:51 PM
WD Pro's Avatar
WD Pro
Will that work with a level 8 without burning anything out ?
Cheers,
WD
Old Feb 11, 2008 | 03:54 PM
Chip's Avatar
Chip
I'll measure the resistance of that and my cossie one when im home at the weekend, as I dont know.
Probably though, L8's are tough as old boots to be fair, lol
Old Feb 11, 2008 | 04:00 PM
WD Pro's Avatar
WD Pro
Old Feb 11, 2008 | 04:05 PM
Chip's Avatar
Chip
PS
Talk to whoever wrote your chip though, about if it will actually work, as its response will of course be different, and could end up with it hunting if its not set right.
Old Feb 11, 2008 | 04:11 PM
WD Pro's Avatar
WD Pro
Not written yet
Will be a MSD closed loop / coilpack / ALS / LC jobie though when done just didnt want to mither stu to much as the timescales keep slipping
It will be live map for my spec so I am only really concerned that it wont damage / burnout anything. That type you posted will be easy to pipe up to as I have a modified small turbo inlet / TB
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
