s1 gearbox
Old Feb 5, 2008 | 05:38 PM
rs cab's Avatar
rs cab
Default s1 gearbox
Put a secondhand s1 gearbox in my car at the weekend and went for a drive only to hear it groul If i push the clutch in stop`s.Wonderin if anyone has any ideas.
Cheers.
Old Feb 5, 2008 | 05:42 PM
Moondust_crust's Avatar
Moondust_crust
did you fit a new clutch as the same time mate, could be release bearing
Old Feb 5, 2008 | 06:00 PM
rs cab's Avatar
rs cab
No , didnt fit a new clutch but did fit a new release bearing.
Old Feb 5, 2008 | 06:27 PM
Moondust_crust
does it get worse the faster you go or is it just as stand still you can hear it?
Old Feb 5, 2008 | 07:39 PM
rs cab's Avatar
rs cab
No noise on stand still only when you speed up. It`s a growl like a really bad wheel bearing.
Old Feb 6, 2008 | 09:25 AM
mikedaf2's Avatar
mikedaf2
if its through all the gears then its probably your diff bearings.
Old Feb 6, 2008 | 04:27 PM
Moondust_crust
lsd box mate?
Old Feb 6, 2008 | 04:41 PM
picky775's Avatar
picky775
sounds like fooked diff bearings
Old Feb 6, 2008 | 06:19 PM
rs cab's Avatar
rs cab
Yeah it`s an LSD box is the diff fu#ked or is it the box , or both.
Old Feb 6, 2008 | 06:35 PM
Moondust_crust
no way of telling till you open it im afraid, chances are its your diff bearings as they are often the main cause, either that or the end of the mainshaft is breaking up causing loads of tiny bits of metal to go into the rest of the box
Old Feb 6, 2008 | 06:44 PM
rs cab's Avatar
rs cab
Cheers thanks for the advice, i may take it back out and have a look and go back to using the xr3i box .
Ps you cab is. lookin well
Old Feb 6, 2008 | 08:29 PM
IANS2RST's Avatar
IANS2RST
does thhe speedo work ok? if so its unlikely to be diff the diff bearings.
what oil did u use in the box? most likely to be the mainshaft bearings
Old Feb 7, 2008 | 01:05 PM
rs cab's Avatar
rs cab
Yeah speedo works ok, i used 80- 90 oil.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
