standerd 2wd saph map sensor were is it located
Old Oct 15, 2004 | 10:46 PM
yogi's Avatar
yogi
Default standerd 2wd saph map sensor were is it located
were is the map sensor located is it located on the iner wing on passenger side as does the pipe run to here
Old Oct 15, 2004 | 11:26 PM
yogi's Avatar
yogi
some one must no were a map sensor is located im just double checking that the pipe goes from there to the pic above
Old Oct 15, 2004 | 11:57 PM
JBcos's Avatar
JBcos
map sensor is on passenger side inner wing
Old Oct 16, 2004 | 12:08 AM
SPADGE's Avatar
SPADGE
Yep just beneath the header tank on the passenger side inner wing
The pipe can indeed go where you have arrowed
Old Oct 16, 2004 | 07:28 AM
yogi's Avatar
yogi
well ive got no pipe going to my map sensor will this be a cause why it is over fueling????????? i hope so but the bit were the pipe goes onto the map sensor has broken away but myne is not facing down like yours spadge its just sitting flush on the inner wing above the header tank cheers for the pic tho
Old Oct 16, 2004 | 03:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Thats your problem then, it will be overfuelling badly. You need a new one
manuel boeckx
13
Oct 3, 2015 02:29 PM
mint_s2
Sep 2, 2015 08:58 AM
Anutternutter
24
Aug 31, 2015 01:24 PM
Tim Wharton
Aug 30, 2015 05:46 PM
costina
18
Aug 25, 2015 06:02 PM
