Overfuelling
Old Feb 2, 2008 | 04:45 PM
JohnL's Avatar
JohnL
Default Overfuelling
Has anyone had a problem with escos overfuelling to a point where it wont start?
have change map, cts, fuel pressure regulator, leads and plugs.
had ecu checked ok. is it possible for a chip to just give up? or need remapping?
thanks
john
Old Feb 2, 2008 | 05:52 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Check the TPS sensor, sounds a bit like it m8
Old Feb 2, 2008 | 07:43 PM
JohnL's Avatar
JohnL
never thought of that... cheers mate will do. any ideas of how to test or just buy a new one and hope?
do these go often?
Old Feb 2, 2008 | 08:08 PM
scott-cos's Avatar
scott-cos
i had this problem also. does the fuel pump prime for a few seconds then cut out or does it run constantly. if it runs constantly try taking the chip out and try that. i took the chip out of mine and it started once i cleaned the plugs and no problems since.
hope this helps scott
Old Feb 2, 2008 | 08:16 PM
JohnL's Avatar
JohnL
Hi scott, thanks for reply, fuel pump kicks in and then cuts out like it used to.
can i just take a chip out? will it still run?
I have a collins stage 1 (see pic below)
Old Feb 2, 2008 | 08:45 PM
cossiemanden
do these go often?
You need a voltmeter, and measure the voltage with egnition on, measure the voltage in full throttle and no throttle.
cant recall the ecact data tho sorry.
BUT it has a LOT to do with the fueling
Old Feb 2, 2008 | 09:28 PM
scott-cos's Avatar
scott-cos
hi john im not sure how yours would work as mine is the small turbo cossie and the chip just plugs into the side of the ecu.
Old Feb 3, 2008 | 05:02 PM
JohnL's Avatar
JohnL
will have a go, its in a bit of a tricky place to get to..
how do i test the voltage on it? as in where will i put wires for testing
Old Feb 5, 2008 | 10:01 AM
grcossie's Avatar
grcossie
Default Maybe this can help you
http://www.totenauto.no/teknisk/Sier...nosis_Info.pdf
And no, it would`t start whitout chip
Old Feb 6, 2008 | 04:54 PM
JohnL's Avatar
JohnL
cheers for that mate!
have had it taken to a garage via rac and they have had it plugged into code reader and brought up a few error codes so will keep posted incase anyone has this problem again...
Old Feb 9, 2008 | 01:24 PM
JohnL's Avatar
JohnL
Can a tps sensor die in such a way that it tells the ecu its on full throttle?
radiant red
43
Oct 26, 2006 07:36 PM
robbyridz
Oct 20, 2006 04:43 PM
bunjeeman
Sep 10, 2006 10:39 AM
timrud
Jun 20, 2006 09:05 PM
xr4x4rs
Sep 5, 2005 12:44 AM
