Overfuelling
Overfuelling
Has anyone had a problem with escos overfuelling to a point where it wont start?
have change map, cts, fuel pressure regulator, leads and plugs.
had ecu checked ok. is it possible for a chip to just give up? or need remapping?
thanks
john
thanks
john
i had this problem also. does the fuel pump prime for a few seconds then cut out or does it run constantly. if it runs constantly try taking the chip out and try that. i took the chip out of mine and it started once i cleaned the plugs and no problems since.
hope this helps scott
Hi scott, thanks for reply, fuel pump kicks in and then cuts out like it used to.
can i just take a chip out? will it still run?
I have a collins stage 1 (see pic below)
DANISH cosworth abuser
Originally Posted by JohnL
never thought of that... cheers mate will do. any ideas of how to test or just buy a new one and hope?
do these go often?
do these go often?
cant recall the ecact data tho sorry.
BUT it has a LOT to do with the fueling
Originally Posted by cossiemanden
You need a voltmeter, and measure the voltage with egnition on, measure the voltage in full throttle and no throttle.
how do i test the voltage on it? as in where will i put wires for testing
cheers for that mate!
have had it taken to a garage via rac and they have had it plugged into code reader and brought up a few error codes so will keep posted incase anyone has this problem again...
radiant red
43
26-10-2006 07:36 PM
robbyridz
20-10-2006 04:43 PM
