Starting Problem!
Old Jan 28, 2004 | 03:17 PM
Spinza's Avatar
Spinza
Default Starting Problem!
My 4x4 Sapphire has developed this rather annoying sound when trying to start it. It goes to start then seems to jam with a sudden grinding sound. If i try again more often than not it will start???
It only happens when the car is hot and has been standing for between 0-1 hour. First thing in the morning its good as gold!!
Please help
Old Jan 28, 2004 | 03:50 PM
Might need a new battery or alternator or maybe some new wiring mate.
The starter motor is not engaging properly coz it can't draw the correct amount of current from the battery or down the old decaying wires.
Matt
Old Jan 28, 2004 | 04:35 PM
alan rainbow's Avatar
alan rainbow
starter motor if it was battry or alternator i think it would be worse in the morning
Old Jan 28, 2004 | 04:45 PM
Dave Henshall's Avatar
Dave Henshall
clutch dust - dry spigot at the end of the starter motor - ive had 3 like this on various cars - the brass bush has worn adn when it is warm, scream/screaches when u start when it is warm. recon starter for 60 sheets.
Old Jan 28, 2004 | 05:12 PM
Alvyn's Avatar
Alvyn
is it a HIGH pitched noise you hear?if so it could be the starter or WORSE it could be the ring gear worn on the fly wheel!
Old Jan 28, 2004 | 07:39 PM
Spinza's Avatar
Spinza
cheers guys, Alvyn the noise is a clunk rather than high pitch
Old Jan 29, 2004 | 07:17 AM
Alvyn's Avatar
Alvyn
then the starter needs changing as soleniod is sticking m8!
Old Jan 29, 2004 | 09:28 AM
PJay's Avatar
PJay
Starter motor mate
Old Jan 29, 2004 | 11:42 AM
Fozy's Avatar
Fozy
Mate had the same on his S1. Fine in the cold, but once the engine had been warm would want to start. Nearly bought the new starter myself. Sick of pushing the bloody thing.
Old Jan 29, 2004 | 03:01 PM
Spinza's Avatar
Spinza
CheeRS guys, so the next question is does a normal sierra starter fit a 4x4 cossie???
Old Jan 29, 2004 | 09:27 PM
Alvyn's Avatar
Alvyn
take the starter off and undo the bolts that hold the solenoid together,it'll properly only need a clean up(it's rusty round the terminals use wd40 or something along that line to clean it)! DONT think you can use ordinary sierra starters m8!
Old Jan 31, 2004 | 07:12 AM
Spinza's Avatar
Spinza
Im going to buy a starter today, but before i do the car has started to make this noise when cold now (first thing in the morning) is this common of a starter failure??
Please help as i dont want to shell out for a starter and it not be needed
CheeRS
Old Jan 31, 2004 | 08:58 AM
alan rainbow
defo starter spinza could be ring gear but very unlikely start wiyh the starter and go from there
Old Jan 31, 2004 | 10:05 AM
Spinza's Avatar
Spinza
CheeRS Alan
I have just got a starter for a very good price if its the right one. Fingers crossed it aint the ring gear what sort of symptoms would the ring gear give??
Old Jan 31, 2004 | 12:27 PM
alan rainbow
some times starter would spin fast but not turn engine this is due to exsevive wear or teeth missing iam sure when you fit new starter all will be ok
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
